PNP woes
- Has thanked: 316 times
- Been thanked: 531 times
Hahaha yeah, I don't speak German either! It should work for you though. That program will allow you to clear codes as well.
- Z06killinsbf
- Year and Model: 1998 V70 T5
Messed around with the software some more, it's throwing an AT-313 code. So that points to a faulty PNP switch correct? Even though I put a new one in doesn't mean it's good right?
1998 V70 T5
That is very possible. It couldn't hurt to replace it again and go through the alignment process. I would try to get a used one from a local Pull a Part.Z06killinsbf wrote:Messed around with the software some more, it's throwing an AT-313 code. So that points to a faulty PNP switch correct? Even though I put a new one in doesn't mean it's good right?
- Z06killinsbf
Since the switch pulls signal to ground, would it be beneficial to add a ground wire to one of the mounting studs?
1998 V70 T5
I don't think it would make a difference if everything fits properly. Couldn't hurt, though.
- Z06killinsbf
Did some digging and came to conclusion that the Chinese built PNP is faulty (even after rebuilding it). IPD had Volvo ones on sale so I got one of those, let's hope this fixes my issue.
1998 V70 T5
Interesting. Well, hopefully that was the problem and a new Volvo switch will fix it!
- 798 Views
Last post by polskamafia mjl
- 1179 Views
Last post by anbran1
- 1003 Views
Last post by DEWFPO
- 557 Views
Last post by draser
- 1135 Views
Last post by techedbob
