J.H.C!!
Finally
P2 Clutch pressure plate flywheel release bearing slave cylinder - 2005 V70NAM56 clutch subframe engine drop Topic is solved
JRL
- Year and Model: Several
- Been thanked: 16 times
Re: P2 Clutch pressure plate flywheel release bearing slave cylinder - 2005 V70 NA clutch subframe engine drop
- Has thanked: 1502 times
- Been thanked: 3817 times
The properly functioning release bearing is incredibly light, finger pressure. Daughter loves it.
Mike..that bracket was a clutch adapter bracket that protects the hydraulics, they are plastic. Good news is the bleeder threads into plastic do it never seizes
I was definitely saved by doing this in little chunks of time. I was about 12 hours all in, lost time on the. Engine mount issue and also did a front wheel bearing and all new hoses/coolant
I was getting a bit battle weary at the end. I had a couple of bags that I had not labelled and cross referenced to my notes, which is a recipe for lost time. Luckily I take a lot of pics and those saved me.
I do have one harness clip I'm still not sure is in the right place, and to be fair the NA wiring tray is different than VIDA so I had to write my own procedure. Next time I see an NA P2 I'll flag them over for a look. We've got 6 on our block!
Some more closing notes and slight regret
While you have to engine dropped to pull the trans, you won't get any better access to the AC compressor as its hanging out in the breeze. Definitely should check the clutch gap and then adjust by using shims for real as you get to it easily.
Follow up - when you get P0106 or ECM-104A its because you didn't notice you pulled the vacuum hose of the MAP sensor, mounted above the radiator fan. Volvo didn't notice it either, as they didn't write it into the disassembly instructions.
Plug it back in and you will be fine
Shout out to..
jimmy57 (big help with sorting out the funny options of clutch and PP on this car)
Jim @JRL
Rick
Neil
Wizechatmagr
For their support during this project and its successful conclusion
Link to axle shaft part number
viewtopic.php?f=9&t=84328&p=462550#p462550
Jim @JRL
Rick
Neil
Wizechatmagr
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
*Finally sees this message... Bad me...*
8 years later this car is now at 155k and rolling and clutching smoothly…
