Front end clunk... Anyone tried these ?
- June
- Has thanked: 523 times
- Been thanked: 261 times
Though this is a old post, my S80 had the exact clunk as described in the first post. I replaced everything including the rack with no avail until this year when I had new frame bushings, bolts, and washers installed. Finely the clunk is gone. So +1 for frame bushings. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- Has thanked: 317 times
- Been thanked: 531 times
Yes, the subframe bushings usually begin to fail around that time and are a pain to replace. I just recently installed the iPd inserts in my V70R while I was reinstalling the subframe after installing the M56.Daveliz99 wrote: 01 Oct 2018, 12:50 I'm assuming you mean the subframe bushings fail after 120k and are hard to replace? Is that correct?
Also I read another thread today from a guy who replaced his xc70 sway bar with one from an xc90. He said he had a noise he couldn't find and could also see where something was hitting the control arm. After rebuilding his suspension, he still had the noise. So, are you saying that the noise in his case is likely caused by subframe bushings?
Usually if you have a clunking noise that almost sounds like something stretching, it's probably the SF bushings. Although if something if hitting the control arm, I would look into that first.
Yup, I swapped from a dead AW55 5 speed auto to the M56. I don't have any writeup for mine, but PolskamafiaMJL made a great one: viewtopic.php?f=1&t=70637.Daveliz99 wrote: 06 Oct 2018, 08:14 Did you happen to do a write up or any notes on the M56 install? I'm assuming you swapped from an automatic it sounds like.
I also used a couple other threads from Volvospeed as well as some critical thinking to work through this swap, because I had to do a few things differently to make the FWD transmission work in the AWD chassis, namely the side transmission mount.
- 812 Views
- 1772 Views
Last post by jreed
- 4076 Views
Last post by Beck
- 1848 Views
Last post by estrekal
- 11 Replies
- 3366 Views
Last post by michaelunderway
