Resurrecting this thread...
I also didn’t annotate where my lifters were supposed to go. I had every intention of marking them but when I set the head on its side, thinking the oil film would hold the lifters in, they all fell out. OOOPs.
I have read up on the adjustment procedure for solid lifts, and will be doing that.
My question is: Will I need new lifters?
I assume this if I reuse the old lifters and go through the adjustment process the solid lifters require, just because I get everything within spec doesn’t mean I have necessarily put the exact same lifter in exact same valve. Correct me if I’m wrong, but I am under the impression that you can reuse a cam with new lifters, but you cannot reuse a lifter. I might be answering my own question here, but I m just making sure I don’t waste $300 buying new lifters.
Thanks!
Didn't notate hydraulic lifters position
- 2042 Views
Last post by jimmy57
- 1273 Views
- 746 Views
Last post by stephansvolvo
- 1272 Views
Last post by cn90
- 1440 Views
Last post by jason1980
