There is no valve on The PTC orfice, it is just a hole. The wires are for a heater that keep,it warm
People drilling this are bandaiding the real problem, which is PCV blockage.
White/Blue Smoke from the Tail Pipe 97 R Wagon
- Been thanked: 4071 times
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
It's possible to have blockage on the ports in the block behind the oil separator, but even if everything is clear, there can still not be enough vacuum relief on cars that have some mileage on them.
At this point, it might be worth trying to find a good used turbo to try, just to make sure it's not at least part of the problem.
Pushing oil past the oil cap, after installing a new seal, indicates a pretty good crankcase pressure issue.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
eBay turbos aren’t necessarily bad. If it’s not leaking or making weird noises, it should be fine. I’m thinking of replacing my old 15G, and if I do, it’ll be a Kinugawa 16T (a very reputable brand, also available on eBay).
Opening up the PTC isn’t a bad idea, I’d say, but what you’re doing will not abate the blue/white smoke - if you’re burning oil and water from the block, then opening that up only gives everything more passage (which isn’t a bad thing).
At this point, you should probably pull the separator off the block, and check those passages into the block, as well as confirm that the separator itself doesn’t have issues. If it’s filling up, for some reason, that’ll push everything down to the intake. If that comes to nothing, you’re only left with the turbo and the blow by. Checking the separator and the block ports is free and relative low-labor, at least.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Has thanked: 311 times
- Been thanked: 817 times
And the valve stem seals.Sommerfeldt wrote: 22 Feb 2019, 07:35 ... If that comes to nothing, you’re only left with the turbo and the blow by. ...
Agreed, OP wants to be absolutely certain about the box and the ports into the block.
Reys
- Year and Model: 850T estate '96
The ports aren't a straight shot and there are a few bends that aren't visible. What I did in the past that you can try before pulling everything apart is: take off the oil trap hose thats connected to the valve cover on top and pour abit of seafoam down the tube. You will hear it pouring into the oil pan. By no means is this better than taking everything apart and properly check as there is two ports, the lower may be clogged but the upper may not.
There's a detailed video from our good ol' friend lucky floating on YouTube where he takes apart a 15g, I would take that route with a 50$ rebuild kit and the stepped rings.
You can pull the chra very easily on these cars, a trick to less mess is clamping the two coolant lines with rags and small vice grips.
Sommerfeldt
There are two coolant lines to the turbo (it needs themJhagins1 wrote: 22 Feb 2019, 11:06 I am pretty sure the coolant hoses you are talking about are on the newer s60/v70 not on my 850r. I will yank it all apart again next week and see what I can do about the ports.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 1779 Views
Last post by erikv11
- 12 Replies
- 967 Views
Last post by xHeart
- 2070 Views
Last post by RickHaleParker
- 1830 Views
Last post by volvolugnut
- 1192 Views
Last post by FireFox31
