Are all your new igntionparts OEM ? No aftermarket here, including coil
The lure of cheap parts has been cursed o these pages manifold....all the perfumes of Arabia won’t sweeten a cheap auto part from the junk Bard...
1996 850 Base NA Severe Misfire after smooth running
Open up the cap again and inspect - thats about the right time for blowby to recontaminate the cap and rotor if the engine is plugged up.erikv11 wrote: 24 Feb 2019, 22:16 Are you sure the cam seal is not blown out under the distributor cap, sending in moisture and oil?
Changed title to capture car and symptom
- Has thanked: 311 times
- Been thanked: 817 times
To see the cam seal you may have to do a little more than pull the cap and rotor, also remove the black plate the rotor mounts on. It's a single 10 mm bolt.
zupta82
- Year and Model: 1995 960
Well great news I finally figured it out. The cam seal under the distributor was blown completely out the bore. As in it was loose and flopping around, I have always been tinkering with cars most of my life but with Chevy’s and other GM’s. What attracted me to the Volvo’s was that they practically never rust out. I drove it for about 15 miles and with a car wash. I think I’m out of the woods now. I want to express my gratitude to everyone for the help.
Nice. Up here in NY, even our salt can't kill these things. See you on the Thruway
- 73 Replies
- 30204 Views
Last post by quietcoolone
- 884 Views
Last post by kahl
- 2351 Views
Last post by SuperHerman
- 1899 Views
Last post by RickHaleParker
- 1151 Views
