Cheap Timing Belt Discussion
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
bmdubya1198 wrote: 06 May 2019, 08:29
callahanoffroad wrote: 06 May 2019, 05:20 I'm a bit confused here.
Continental timing belts are only $12... That's pretty cheap to me. Well when I say cheap I mean affordable... Is there a lower cost option? A pack of rubber bands tied together???
Yeah, it's really not worth cheaping out. When you buy the full kit, what could you be saving by going with Dayco or Gates over Continental, $50 max? It's just not worth it to save that $50 in the long run.
To clarify, the belts aren't the problem with those kits. I'm more concerned about potentially poor quality pulleys/bearings.
I'll agree there. I was sold on the better parts for no other reason than they are made by Aisin. Guess who makes all of Toyota's hydraulic parts and carbs? Aisin. Aisin makes a quality product.
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
"Continental timing belts are only $12" "Continental timing belt kits $50 max"
Where? .......
Active
Past
callahanoffroad
RickHaleParker wrote: 06 May 2019, 13:23
Where? .......
I'm sorry it's $11.91...
https://www.fcpeuro.com/products/volvo- ... ntal-tb252
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Where? .......
I was referring to the price difference between Continental kits vs. the low end brands. Kits are around $225 with the water pump, IIRC.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Where? .......
Yeah, what were you asking here?
Or at RockAuto https://www.rockauto.com/en/parts/conti ... +belt,5716 it is currently $5.55 on closeout (stock up!), $11.34 for regular inventory, etc. ...
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
everything is cheap except the pump. I only replace the pump after 200k if its original. If its no name I always replace it. I dont bother with the tensioner as I've never seen a bad one. Just dont stick it in a vise and crank it down fast. so that leave 2 rollers and belt. around 120 for Volvo or INA. and continental. Im sure there is no problem with gates, only their kit is sub standard for the rollers and especially the pump. The pump will eat the belt if it seizes up. If the rollers seize there is smoke and a good chance you will hear the shrieking. the belt will not break till it melts or the roller falls apart. so you will usually catch it unless you lent the car out.
Post by erikv11 »
tardcart wrote: 06 May 2019, 16:48 ... I don't bother with the tensioner as I've never seen a bad one. Just dont stick it in a vise and crank it down fast. ...
That (hydraulic) tensioner stopped being used in 97 (OK in a few 98 vehicles too). This thread is about a 2000 V70 which has a mechanical tensioner/roller that should be replaced every time.
The hydraulic tensioners from Aisin have great longevity though, I agree with you there.
And don't throw away a factory pump with under 200k on it! Totally agree! Happens all the time, I see a 150k P80 car for sale and the ad says "water pump just replaced!" which is usually very bad news ...
tardcart
Post by tardcart »
Ahmen! I should keep my nose out of 2000 up since I dont know anything about them.
RickHaleParker
erikv11 wrote: 06 May 2019, 16:26 $5.55 on closeout (stock up!), $11.34 for regular inventory, etc. ...
Stock up on old stock? Contitech TB252 70,000 miles or 8 years.
Active
Past
tardcart
Post by tardcart »
just ordered one. its cheaper to get one than two as it goes first class which is cheap. 2.99 ship. If you are not scared of old rubber sold cheap,Here are the finest tires ever made, AA traction. free ship and 20 off a pair if you pick them up north Philadelphia . says 2014 but I bought 8 and it was a mix of 2017 to 2015. 130 a pair picked up cash. ask for Wes.
https://www.ebay.com/itm/4-New-205-55-1 ... 592720fcea
