2006 XC70 Hot starting issues Topic is solved
Rvolvos
Year and Model: 2006 xc70
Has thanked: 73 times
Been thanked: 23 times
Post by Rvolvos »
E Showell wrote: 22 Dec 2020, 07:28 Which cylinder is dead? Move coil pack from a working cylinder and see if the misfire moves. I consider coil packs a 100k maintenance item, although many will run 'til failure.
Spot on, I guess I did too. But I did swap the coils from our V70 with @153k. I put back the original coils in cilinder 1 and 5 and it starts and runs fine😅
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
So how about that? Your Volvo isn't dead after all. Just nicely broken in at that mileage.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Rvolvos
Post by Rvolvos »
Does anyone know what the values for the Front and Rear oxygen sensors should be?
Attached a picture of the values when idling. Long term fuel levels look good, to my knowledge they should be around 1.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
Rvolvos
Post by Rvolvos »
Considering this topic solved. I have put in new coils from FCP Euro and the car starts fine cold and warm.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
Rvolvos
Post by Rvolvos »
After the timing belt and vvt hubs installation I scanned the car for codes to make sure if no errors where introduced.
I did replace the starter with a lower mileage one ( had to remove the starter anyway for the vvt hub replacement) and prior to the the antenna ring.
The following codes popped up for the first time.
ECM-291D fuel pump control module- signal to low ( Pem has been swapped with one from a 2011 c30 (124k))
CEM-3F90 fuel pump, relay open circuit or shorted to ground
Multiple instances where recorded, but not much detail information other than to check the wire harness.
Any one got these codes too?
2006 XC70 2.5T 238k
2012 S60T6 95k rip
Rvolvos
Post by Rvolvos »
Please ignore the post above. DTC must come from fuse removal from fuel pump and cranking the engine.
Happy to report that the car starts consistently with the newer starter.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
jonesg
Year and Model: 2004 V70
Been thanked: 532 times
Post by jonesg »
if only it was always this simple.
