Nevada1906 1995 850 S60R m56 build thread
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Nevada1906 wrote: 09 Oct 2021, 18:55
You know, I think you're right. Thanks for pointing that out.
Now I wish I hadn't taken the accessory drive back apart - I won't be able to confirm this routing until it goes together for real.
I seem to recall there being a different belt, as well. However, my memory is fuzzy on that part. I think the PN for this routing is 9186352.
I know my '97 T5 still had the original routing on it when I bought it.
Has thanked: 1609 times
Been thanked: 4065 times
Take the time now to replace those hose clamps on the turbo cooling return line with oetikers. Those will be Hades to fix when they loosen up,
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
abscate wrote: 12 Oct 2021, 02:50 Take the time now to replace those hose clamps on the turbo cooling return line with oetikers. Those will be Hades to fix when they loosen up,
+1 on the clamps, and our friend Robert says that is an excellent spot to use a Volvo hose. A few years back when I had to wrestle with that issue I bought Blue Box, but used a constant tension style clamp, since I didn't have the Oetiker stuff yet.
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
How much pressure does that line normally carry?
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Nevada1906 wrote: 12 Oct 2021, 12:47 How much pressure does that line normally carry?
Not a whole lot, the cooling system holds at around 22 PSI/150 kpa.
Nevada1906
foggydogg wrote: 12 Oct 2021, 09:06
Sounds like some 1/4" zip ties would do the job. If I really horsed them down.
foggydogg
Post by foggydogg »
The point Abscate was trying to make is that hose is very hard to access once the motor is in the car. Ask us how we know this.
Robert DIY has mentioned more than once he only uses a Blue Box hose in that position for the same reason. If you have to do any serious manipulation of the hose, or the clamps, it can put a lot of strain on the tubing itself, which can lead to more serious issues.
As mentioned above, it gets full system pressure.
I personally would not use zip ties on anything in the coolant system.
bmdubya1198
Either some good worm gear clamps (ABA, AWAB, etc.) or Oetiker clamps are the best option. As for the hose, blue box is cheap, and silicone is another safe option.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Heat and age will cause zip ties to fail. Sure they will hold pressure for awhile, but then you have to get in there to replace. Mean while they may have dump your coolant and killed your engine.
Nevada1906
This is why I don't do stand-up...
