dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
I had changed my two LCA to two used ones until I get both my old LCA's with new bushings. So far only one is done, but soon. In the meantime the two used LCAs I installed are much better than the old ones and car is much more stable on the road, it's perfect.
Additionally I finally went for alignment and things are now better with tracking and overall feeling.
Onto the fuel wars: Some were asking about 95-100 octane(EU octane rating). In my country all the fuels are E10 or have about 10% Ethanol content which as the name subtly implies reduces MPG by 10%, the car goes from an avg of 8.9 fuel consumption under normal driving conditions, to 10l/100km.
But lets focus on power, with 100 octane, my 2.4i produces less power, less oomph in my opinion. Logging the car I see almost no knock compensation, but as soon as I mix the fuel with regular 95 octane, the response and sound are amazing. Still, the E10 also robs my car of power. And my country does not sell E0 or even E5.
So maybe the sweet spot in my opinion is either pure 95 octane or a mix of 95 and 100.
Thirdly this not fixable without a rebuild but now I know more about my AW55. The torque converter clutch is indeed in a bad condition. Our Volvos have three modes of operation. Not locked, Slip Lockup and Fully Locked, in Unlocked and Fully locked I have not seen any problems, but in Slip Lockup my clutch is slipping too much and I get torque converter shudder in some situations. These situations are when you put gear lever position in say 3(for 1-3 gear limit), this forces the gearbox to lock TC earlier, but the point between locked and slip lockup is where it slips more than it should.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Replaced the rear driver's side Toe Adjustment Bar. Will align tomorrow.
viewtopic.php?t=103914
MoVolvos
Post by MoVolvos »
09 S60 2.5T AWD
Found the rear sunroof drain lines. Was looking under the car while replacing the rear Toe Adjustment Panhard Rod. Couldn't see anything so decided to look elsewhere.
Used compressed air to clean every part and direction then tested. Had cleaned two fronts with a weed wacker line previously and the driver's side rear drained test okay at the time also. Used a large amount of water resulted in water overflowing the passenger side into the vehicle.
Everything tested fine today after the compressed air cleaning, Front carpets to return into the car and rear area will be reinstalled after a heavy rain, just in case. Driver's side drain is easier to get to whereas you can't see the large grommet on the passenger side.
MoVolvos
Post by MoVolvos »
MoVolvos wrote: 24 Jan 2024, 23:04 .
Performed a 4 wheel DYI string alignment today. Front set to zero Toe while rear is Toe In 1/8" each side for a Total Toe of 1/4".
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
MoVolvos wrote: 25 Jan 2024, 17:19 .
And the thrust vector is unknown ;)
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
jonesg wrote: 18 Jan 2024, 10:49 Bought flex pipe for exh downpipe.
Correct fit? I watched what seemed like 3 orangex videos totalling about 3 hours regarding that job and learned nothing.
04s60 2.4
04xc70 2.5t
MoVolvos
Post by MoVolvos »
vtl wrote: 26 Jan 2024, 11:21
With most modern cars Toe and sometimes Camber is all that can be adjusted so none of the others specs from an alignment machine are needed. The only time it matters is if you have bad tire wear and if you suspect damage whether from a curb, huge pot hole or car has been in a collision. The rest of the time it's replacing worn parts to put things back to Stage 0. The only other time others specs are needed is if everything is within spec yet the car still does not track straight, then the other specs will be helpful to make fine adjustment to dial in good road behavior.
Use the have 4 ASE's in the mid 90's and one was the (A4: Suspension & Steering). You know what they say about not using and loosing. I was a good test taker but lack time in the field... One of these days I'll do a write up on how I do a 4 wheel alignment. Have always done 2 wheel alignments but in the last 2 years or so decided to give the 4 wheel DIY alignment a try. Kind of interesting and gaining more insight each time I do them.
Antoine240bk
Year and Model: XC70 2.5T-2006 - 4C
Has thanked: 12 times
Been thanked: 30 times
Post by Antoine240bk »
Been long since i posted here but i still have that great car. well some work was required to keep it running well.
The exhaust front and rear. Front Four C shocks. Front Stabilizer bar and sway bars. Crankshaft seal and Oil pump seals.
I refurbished the plastic headlights glasses with new ones.
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Got oil report back from Blackstone Labs. Overall great for an engine with 164k miles, first sample I’ve pulled on this car. Yet to do coils, fuel level would seem to indicate they may help fuel economy.
08 C702.5T (sold)
The non-Swedes:
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Antoine240bk wrote: 27 Jan 2024, 03:36 Been long since i posted here but i still have that great car. well some work was required to keep it running well.
Thats a great looking wagon!
2003 XC 70 (sold)
