Vida CEM swapping
MaxDenisov
Year and Model: XC90 2010
Has thanked: 2 times
Post by MaxDenisov »
Done using OBDII!
@Vitaliy Thank you very much!
Key position -0
Same wiring as used before. Just used charger for laptop during pin finding.
Code: Select all
CPU Maximum Frequency:   600000000
CPU Frequency:           180000000
Execution Rate:          180 cycles/us
Minimum CEM Reply Time:  30us
Platform:                P2
PIN bytes to measure:    3
Number of samples:       60
Number of loops:         1000
CAN high-speed init done.
CAN low-speed init done.
Initialization done.
jcdillin
Year and Model: 06 V70R
Been thanked: 3 times
Post by jcdillin »
Awesome!
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Congrats! So it again comes to a wire gauge question (use thick wires) and whether a good source of power is needed (it is needed).
Also I see SAMPLES are set to 60, which also helps to distill the signal in all that noise.
jcdillin
Post by jcdillin »
Yeah, I think it's mostly a noise issue in the car.
I emailed D5T5 and they will accept the pin to update to your account for configuration changes. I'm just waiting for them to update mine to see if I can do the manual configuration change in the CEM.
vtl
Post by vtl »
They probably have your pin already from here ;)
Wondering how many people are following this thread... I talked to like 30+ folks over email in these few months since the first pin got cracked.
MaxDenisov
jcdillin wrote: 09 Mar 2021, 13:58 Yeah, I think it's mostly a noise issue in the car.
I also just sent my pin to D5T5 and will share some news after.
I want to add extra key and remote instead of lost one.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
MaxDenisov wrote: 09 Mar 2021, 12:03
vtl wrote: 09 Mar 2021, 11:52 What kind of CEM is it? Is it based on Renesas?
How to check it without disassembling?
99.9 % sure this is all correct.
P1 - Motorola S12 chips.
2007–2013 C30.
2013–2019 S40II
2004–2012 V50.
2006–2013 C70II
P2 CEM-H Motorola MC68386.
1999 - 2004 S60, S80, V70II, XC70, XC90
P2 CEM-L Renesas M32C.
2005– 2009 S60.
2005 - 2006 S80.
2005 - 2007 V70II.
2005 - 2007 XC70.
2005– 2016 XC90
Active
Past
vtl
Post by vtl »
-MY2014 XC90. MY2015 was SPA.
RickHaleParker
MaxDenisov wrote: 09 Mar 2021, 13:34 Same wiring as used before. Just used charger for laptop during pin finding.
Power supply board not enough current capacity?
Active
Past
MaxDenisov
RickHaleParker wrote: 09 Mar 2021, 15:01
I just thinking that Vitaliy is right, better to have dc/dc converter 12v-5v.
I had some difference/issues because of power supply and long wires
