MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
crasbe wrote: 25 Mar 2024, 12:06 In January the rusty exhaust of my S60 decided to finally develop a hole in the rear muffler. As you typically do in such cases, I ignored it :D
Unfortunately the hole didn't decrease in size and the exhaust got progressively louder. Therefore I ordered new mufflers from IMASAF and procrastinated for another month until Saturday, when I finally ripped the old exhaust out:
It went smooth so far, but one of the four bolts of the front exhaust guard (VIDA calls it "bracket") stripped. I expected the bolts close to the downpipe to strip but not one in the chassis :?
Then I decided to open the can of worms and remove the heat shield as well. It was a good and bad decision. Good in a sense that I uncovered a lot of rust, which had to be treated. And bad in a sense that I uncovered a lot of rust, which had to be treated. The spot welds of the rear heat shield came apart in the process, so I had to rivet them back together.
All the surface rust was ground down with a CSD disc and painted with Brantho Korrux 3in1 (the German equivalent to POR15 essentially).
The exhaust hangers were derusted in citric acid, neutralized with soda and then painted with Hammerite. The next time (if there is one..) I'll make new exhaust hangers from Stainless.
The installation went quite smooth and the IMASAF exhaust fits very well.
All in all the "just swap the exhaust on a Saturday" took three days and was significantly more work than expected.
If there only was a 1:1 replacement exhaust for P2 Volvos made from stainless steel (with TÜV approval)... :(
Nice work. The IMASAF exhaust looks like a quality unit. Love your large work area and the brick pavers.
crasbe
Year and Model: 02 S60, 98 V70 (EV)
Has thanked: 33 times
Been thanked: 82 times
Post by crasbe »
MoVolvos wrote: 25 Mar 2024, 15:44 Nice work. The IMASAF exhaust looks like a quality unit. Love your large work area and the brick pavers.
Thank you :)
Yes, so far we had good success with the IMASAF exhaust on my partner's Volvo V70 II, so I went with them again.
I'll have to check when the rear muffler was last replaced by the previous owner, but I think it was less than 5 years ago? It was not from IMASAF though...
When fitting the heat shield, I had problems with the plastic nuts (981495), because the threads of the studs were corroded and had less diameter than they should have. The studs were shorter as well, so I drew up and 3D printed a replacement nut, that sits a bit more snugly on the stud and is additionally held by a zip tie:
Initially I had some problems with layer adhesion of the ABS plastic (the layers are the weak point of 3D prints), but after some tuning it came out pretty strong.
If anyone is interested, the models for the long and short nut are published on Printables :)
https://www.printables.com/model/818307 ... nut-981495
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables :D
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Out and about today in Kära and a couple of pics before she gets tucked away again. She's still looking good at over 18½ years old
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
P80GLT
Post by P80GLT »
My V70 is already green so I don't care...
High Emissions.png (268.24 KiB) Viewed 2767 times
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Replaced my 4 spoke leather steering wheel with a wood wheel.
Wood Wheel.jpg (92.09 KiB) Viewed 2761 times
2003 XC 70 (sold)
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
That looks nice!
Blacklab467
BlackBart wrote: 27 Mar 2024, 21:15 That looks nice!
It’s a nice piece of lumber, I believe it’s red oak or something. I feel like I should be smoking a pipe while driving it now!
2003 XC 70 (sold)
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Blacklab467 wrote: 28 Mar 2024, 05:23 It’s a nice piece of lumber, I believe it’s red oak or something. I feel like I should be smoking a pipe while driving it now!
Only when playing ABBA on your cassette player!
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Perhaps a flat cap as well
Has thanked: 1611 times
Been thanked: 4074 times
Rolled the P2 into Brooklyn to pickup daughter and hound. 90 minute trip at 35 mpg as rain limited traffic speed.
