Do it yourself ABS module repair. Topic is solved
This topic is in the MVS Volvo Repair Database » Do It Yourself ABS Module Repair
aisrael
Year and Model: 1993 244 1995 854
Re: Do it yourself ABS module repair.
Post by aisrael »
My 99 V70 NA has the Tracs, abs, check engine, and brake lights are on witb speedometer not working. I am 99% sure it is tbe module. Has anyone used Midwest ABS before
Is the repair difficult to fix myself?
Aaron
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
MidWest ABS is Matty-Moo from this site and can be 100% trusted. Good work at a fair price. Don't hesitate.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
woodchopper wrote:Many thanks to everyone for all the work and pictures you have contributed. My ABS light was coming on infrequently. I took it off and apart. I could not see any cracks in the solder using a magnifying glass so I decided to just put it back on without doing anything to it. I sprayed the connectors and the metal tubes that the module slides onto(electrical contact cleaner). The light has not come on yet but it has only been a day or so. Makes me wonder if it was just the connectors needing to be cleaned. So I just wanted to suggest that anyone with the ABS light coming on try spray cleaning the connectors before going to all the work of tearing the module apart.
This is on a front wheel drive non turbo. I don't know anything about the tracs issue.
By disturbing the board and moving it and putting pressure on it you've temporarily alleviated the symptoms by closing the cracks in the board; but the symptoms will be back
richeros
Year and Model: XC90, 2005
Post by richeros »
Hi everyone and thank you Lee for this post.
I registered here just to say that I took a chance on my 2005 XC90 and went ahead with this fix.
All the symptoms where there and Volvo estimated me 2200$ for a new unit.
And guess what it worked out just fine. The ABS light was still on after the fix but just like described here it turned itself off after a minute or two of driving.
Ive been around a lot after the fix and everything works just fine.
Thank you guys and of course Lee!
Richard
Andrew ren
Year and Model: S70 1999
Post by Andrew ren »
So I went ahead did my abs module. All went fine, but the CEL still on even after 100 km driving. I was getting the up arrow and CEL first then I got it reset @ my volvo garage, 10km after that I got abs/brake/CEL all on right after I left the garage, then all the other lights went off on their Own beside the CEL(this is the one permanently on).
And this is the one still on. My questions is, did I fix it or not? Can the CEL turn off by itself after you perform THE DIY. Or I have to get it reset and go from there.
igel513
Year and Model: 2003 S60 T5
Has thanked: 1 time
Post by igel513 »
You have to have your codes read if you don't have a scanner. They can erase the cel then observe if it comes back or not. If it doesn't, you've fixed the problem
Andrew ren
cool will do that.
is it must a special scanner(volvo type) or a common one will do(reset the CEL)?
Andrew ren
started like this a month ago
Andrew ren
got it reset and then came back like this after 10km driving
Andrew ren
performed the DIY.
Now the CEL is the only light still on, and it was the only light stays on right before the DIY.
