excellent cracker, now with new code P1 work too
Vida CEM swapping
- RickHaleParker
- Been thanked: 979 times
Neat package! What is that CAN BUS Transceiver board you used?
Welcome to MVS.
Active
Past
Past
- RickHaleParker
Are you going to contribute a Gerber file to the project?
What chips did you use?
Looks like you are drawing power from Vusb. In the current schematic that is listed as an unknown. Can you confirm Vusb has significant power to run the assembly?
Active
Past
Past
solitaire
- Year and Model: v40 2016
- Has thanked: 3 times
- Been thanked: 6 times
RickHaleParker wrote: 20 Mar 2021, 12:13 Are you going to contribute a Gerber file to the project?
for CAN I use max3051 (3.3V), powered direct from teensy (max 250mA), https://www.pjrc.com/teensy/card10a_rev2_web.pdf
max3051 maximum current 70mA x 2 = 140mA (https://datasheets.maximintegrated.com/ ... AX3051.pdf)
gerber and box for 3D attached
- gerber_teensy__4.rar
- (3.33 KiB) Downloaded 327 times
- korpusas.rar
- (3.89 KiB) Downloaded 301 times
- RickHaleParker
USB 5V 500ma is standard.solitaire wrote: 21 Mar 2021, 09:33
Teensy 4.0 current is ~100ma.
~100ma + 140MA = ~250ma.
~ 50% of the minimum standard.
No risk of overloading the USB port or coming up short on power.
Active
Past
Past
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Is this intended for swapping CEM modules with used ones without dealer involvement?
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
A part of that, yes. We miss acloning software that pulls the flash and EEPROM from damaged CEM over CAN and writes it to the donor CEM.ZionXIX wrote: 21 Mar 2021, 14:32 Is this intended for swapping CEM modules with used ones without dealer involvement?
- 9028 Views
Last post by RickHaleParker
- 8864 Views
- 27 Replies
- 27732 Views
Last post by cn90
- 10279 Views
Last post by jonesg
- 5473 Views
