CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 327 times
Been thanked: 87 times
Post by CIK7 »
ZionXIX wrote: 23 Jul 2020, 13:12
CIK7 wrote: 23 Jul 2020, 12:15
bmdubya1198 wrote: 22 Jul 2020, 11:49 Ugh those quick disconnects SUCK. Such a pain to release. I bet that orifice tube is nasty, mine was caked up with so much garbage. I guarantee someone used stop leak to try to fix the evaporator leak, but of course it won't work since it couldn't get past the orifice tube.
There are 2 lines running underneath the coolant reservoir to the firewall. The smaller line is actually 2 lines bolted together. The orifice is in that smaller line. You have to remove the line completely before opening. I did it the hard way. I recommend unbolting the pieces behind the headlight before disconnecting at the firewall. It will give you more flexibility. Pay attention to the direction of the orifice when replacing.
thank you. i will keep that in mind.
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 1505 times
Been thanked: 3818 times
The orfice tube is the heart of the system it controls the expansion of the high pressure coolant to low pressure, generating the cooling power
I put ina custom passenger foot vent for those smelly soccer feet
Maddy silver bullet98 , Catherine 05 , Clarke 98 , Ekaterina 99,the Nabber 99,  and Ludwig Van.  Elizabeth and Evita  were out on patrol.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
abscate wrote: 24 Jul 2020, 19:31 The orfice tube is the heart of the system it controls the expansion of the high pressure coolant to low pressure, generating the cooling power
I'm gonna show that picture with all the cars to my wife. She always complains I have too many cars 😆
BMW 540i 2002
S70 Base 2000
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
kallekula wrote: 25 Jul 2020, 09:30
The Nabber 99 is mine so it's not as bad as it looks!
07 V50 T5 AWD M66 ~146k miles
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
smacknab wrote: 25 Jul 2020, 11:28
What looks bad? :lol:
2000c70hpt
Year and Model: 2000 C70
Has thanked: 1 time
Been thanked: 8 times
Post by 2000c70hpt »
abscate wrote: 19 Jul 2020, 19:20
2000c70hpt wrote: 19 Jul 2020, 16:58 I’m getting ready to do the cam seals on Charlie. My c70.
Read up on VVT which you will have in the exhaust cam. You need the cam lock tool.
Hopefully, you won’t have to retime it 11 times like me before the Stupid was purged.
Yeah I bought the tool about a month before I decided to start the job. Replaced all cam seals whether they needed it or not, changed the front crank seal as it was leaking, and only got an ets light when done. Probably due to pulling the main relay to turn it over. Yes I turned it by hand first. Changed the serpentine belt tensioner pulley and replace the upper torque mount on the engine. No more oil leaks from the engin. Now to figure out the transmission leaks. I think it’s the case seam but I’m hoping it’s just axle seals, and a pan gasket.
2000 C70 hpt with 140k
2008 xc90 t6 non turbo with 170k
smacknab
Post by smacknab »
Prepped for and started the engine removal to do the clutch/flywheel/release bearing. Stopped as I was losing light and I couldn't disconnect my clutch line from my release bearing assembly. I'm leaving it to soak in PB blaster overnight, but how bad does this look? My thought is that the line doesnt have nearly as much pressure as a brake line so I could get away with not replacing it. Any thoughts?
When the rust perforates the line, you will have no clutch. You good with that?
volvolugnut wrote: 25 Jul 2020, 12:09
Man Beetle hiding in garage
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Yeah, it would probably be a good idea to order a new line.
