- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
My temporary visqueen and Gorilla tape to keep what’s left of the grease in my CV joint got cold and is now making a flap flap flap noise. Too cold and snowy to fix it outside.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Failing mounts and bushing season continues. 10-years and 70k+ miles later, the pair of Meyle HD LCA may need an upgrade.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
10 years and 93k miles ago I replaced just the bushings, with OE. May need to inspect them after winter, but they were still OK last fall.xHeart wrote: 31 Jan 2025, 06:55 Failing mounts and bushing season continues. 10-years and 70k+ miles later, the pair of Meyle HD LCA may need an upgrade.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
they sell collars that go around the original cv boot .BlackBart wrote: 28 Jan 2025, 21:52 My temporary visqueen and Gorilla tape to keep what’s left of the grease in my CV joint got cold and is now making a flap flap flap noise. Too cold and snowy to fix it outside.
Still too cold though. 17F here, funny ... it feels like 16F.
vtl
All I can do in this weather is pulling a DEM fuse, so driveshaft's dead u-joint is not loaded. Big Yotas are parked for month+ now: they don't heat up as well as old Volvo does. Plus all that road salt... Old Volvo does not care about it. Mostly.jonesg wrote: 31 Jan 2025, 17:25 they sell collars that go around the original cv boot .
- Has thanked: 987 times
- Been thanked: 1078 times
Not a problem - it's a feature. Remember playing cards noise makers on bicycle spokes?BlackBart wrote: 28 Jan 2025, 21:52 My temporary visqueen and Gorilla tape to keep what’s left of the grease in my CV joint got cold and is now making a flap flap flap noise. Too cold and snowy to fix it outside.
volvolugnutr
I’m trying to fix my headlight control module in my 03 xc70. Reflowed solder and checked all the connections and metered everything, it’s functional but it won’t come back intermittently. Someone I know mentioned the large capacitors might be dry and struggling to get started until the car is warmed up.
Capacitors have a working life and often fail. They are easy to replace if you can identify the rating and can solder.
- BlackBart
We're having a mini-blizzard over here, mostly due to one of those North Dakota cold blasts spilling over the mountains. Hard-packed slippery streets, deep drifting snow. I'm getting the odd sensation I am not getting any AWD. You know that FWD feeling with wheel spin and the front end wandering sideways? - it's not grabbing and moving forward. And it has new Blizzak snows on it.
I'm not sure yet, I need to find an empty place I can goose it and turn and see if the rear is kicking in, or if it's delayed somehow.
And the garage is of course filled with old cars and loose engines and axles, so I can't pull it in.
I have a garage and two shops and I have to work on my cars outside. sigh.BlackBart wrote: 05 Feb 2025, 12:54 We're having a mini-blizzard over here, mostly due to one of those North Dakota cold blasts spilling over the mountains. Hard-packed slippery streets, deep drifting snow. I'm getting the odd sensation I am not getting any AWD. You know that FWD feeling with wheel spin and the front end wandering sideways? - it's not grabbing and moving forward. And it has new Blizzak snows on it.
