bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
wizechatmgr wrote: 13 Sep 2020, 00:27 Happen to replace the turbo control valve? My guess is the pressure may be getting high enough to push through it. If it isn't the CBV or a hose, my guess would be this... (Assuming the ECU isn't causing the issue intentionally)
I can't totally rule out an issue with the ECU given other problems I've dealt with (flickering CEL that I've pretty much traced to an internal ECU problem) but there are 3 things I'm thinking at this point. TCV (unlikely since it's new, but anything's possible), ECU, or a clogged up cat.
matthew1 wrote: 12 Sep 2020, 08:48 Sounds like a collapsing hose or old/torn/leaking CBV.
I've got a Japanifold hanging on the wall in my garage. Hint to myself.
The CBV is in good shape and not very old, so that's unlikely to be the problem. The IC hoses are in pretty sad shape, so that's a possibility. It could explain the inconsistent boost... sometimes it'll boost to 15 PSI with little issue, other times it takes its time to get there. I feel if it was in fact a clogged cat, it would be more consistent. It's slow to boost either way, so anything's possible.
In other news, this appeared today. 400 hp M66 S60R! My buddy just bought it and dropped it off for some work. He drove it 4 hours up here from Georgia (where he bought it) with a totally missing control arm bushing. It was all over the road, but he made it safely!
Has thanked: 1505 times
Been thanked: 3818 times
Woof. Youth is wasted on the young.
(Seriously, that's a park, DO NOT DRIVE type issue. If that comes out of the control arm, life gets....interesting.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2654 times
Been thanked: 1248 times
Post by matthew1 »
Whoa.
Also -> Amazon link
bmdubya1198
abscate wrote: 13 Sep 2020, 09:04 Woof. Youth is wasted on the young.
He had no idea, he was told it was the passenger CV axle by the previous owner. I drove it around the neighborhood and decided there's no way in hell that's the only problem. Jacked it up, and sure enough... no bushing! I wouldn't have let him drive it if I had known this was the problem. It seriously jerks all over the road.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
bmdubya1198 wrote: 13 Sep 2020, 09:00 In other news, this appeared today. 400 hp M66 S60R!
Where is the extra 100 hp coming from? A slip of the finger perhaps?
It’s a new product at your FLAPS ...
Hundred horses in a can,,,,,
matthew1
Site Admin
Post by matthew1 »
That bushing looks less like it was worn away and more like it's a 4,000 year old Egyptian mummy, where soft tissue has disintegrated.
Also -> Amazon link
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
Impressive, but wonderful car...
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Had fun with a seized but not seized parking brake on the project car. It was stuck on so the rotor did not want to come off (pushed outwards onto the rotor so you could not pull it straight off). Had to pry in some impact bits to give me enough space to gently leverage the parking brake back inside. Turned out that letting a car sit results in rust buildup inside the rotor. This was enough to rub onto the parking brake pads and lock the wheels fully, a good cleaning fixed that. Now to find a flare wrench to replace the front callipers.
2008 S60 2.5T Auto (Sold)
bmdubya1198
Allegedly the PO had dyno'd the car and it made 400 AWHP. Allegedly... lol. I believe it though, it's pretty quick!
The bushing must have been degrading for a long time, I don't know how the guy let it get that bad. The interesting part is that the remnants you can see there are from a poly bushing... weird. The other arm has a standard rubber bushing.
I could see it now... 100 hp in a can: new from CRC!
