just did a simple mod and WOW!
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
s70glt novice[Will]
Year and Model: s70 glt 98
Re: just did a simple mod and WOW!
Post by s70glt novice[Will] »
trophytaker308 wrote:obx turbo to be exact....like whats listed in my sig....lol.
It was late. I think. :oops:
Anyway, looks great. I dont know if that auto will hold up to the power. It's the main reason i stuck with a 16t instead of 18t. That and spool time. The GLT also has weaker connecting rods.... so we'll see how that works out. :D
'98 s70 GLT-127k
ARD Green, obx, 16t, other go-fast parts
trophytaker308
Year and Model: 1995 850t turbo
Post by trophytaker308 »
i dont have a glt....i said i was going to put glt cams in it,as a upgdae.....i have a t-5.
1995 850t turbo,siver with black leahter interior (perfect),, 118000 miles .second owner.9 out of a 10...!
trophytaker308
lucky has the exact same set up as mine and said its a great combo and he is pushing 295-300hp..im also going with the blue tune like it says in my sig....lol
trophytaker308
it will hold up,just put new trans synthitic fluid in and also getting a tranny cooler,so it will be just fine.
trophytaker308
and if the tranny happens to go,this will be in it next time....
http://www.vivaperformance.com/spec-clu ... urbo-t5-1/
ChiNorm
Post by ChiNorm »
Nevermind. I missed all the extra pages.
trophytaker308
whats that have to do with the glt cams,im not putting glt rods in,and if you mean push rods then i am going to uprage them when i install the cam and lifters.....so please explain.
ChiNorm
Post by ChiNorm »
OHC motors don't have pushrods. ;)
bugsbunnies95_850t
Year and Model: 99 v70R
Post by bugsbunnies95_850t »
tranny is good till 350 with a good cooler and frequent flushes 320 without cooler .. at least thats what ive heard of and ive done TONS of research on mods for my old 850 till a connecting rod bearing went .. now i have a 99 v70r
s70glt novice[Will]
Anyway, looks great. I dont know if that auto will hold up to the power. It's the main reason i stuck with a 16t instead of 18t. That and spool time. The GLT also has weaker connecting rods.... so we'll see how that works out. :D[/quote]
it will hold up,just put new trans synthitic fluid in and also getting a tranny cooler,so it will be just fine.[/quote]
whats that have to do with the glt cams,im not putting glt rods in,and if you mean push rods then i am going to uprage them when i install the cam and lifters.....so please explain.[/quote]
Sorry for the late response. It has nothing to do with the cams. The GLT has weak connecting rods. and they like to bend under lots of boost. I also dont feel like investing in an A/T cooler, so i kept the power low. Still fun as hell to drive. I'm thinking (really really hoping i'll be able to) of doing a manual swap. I gain ponies at the wheels, and can get a bit more power. I also haven't touched intake,(IC,tubing) so thats my limiting factor right now. Either sconeman's tube or an FMIC is in order. And i have done a fluid change on the A/T. I would recomend N/A cams instead, because while you're in there, you might as well go balls to the wall ;)
'98 s70 GLT-127k
