(Simple + i * Simple) Key Fob Question 1998 v70
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hello there,
I have not used the key fob in something like four years. Back then it worked fine, and it probably still does I just have to test it tomorrow.
What I was wondering is, if the little internal battery went dead and I take it apart and replace the battery, will it still be "paired" with my Volvo?
Keep in mind it was fine last time I used it. I'm just worried that if I change the battery I might have to do some kind of sequence to get it paired with my actual Volvo again so it works the doors again and all that stuff.
Thanks for any information about this.
Has thanked: 1609 times
Been thanked: 4065 times
Search for pairing fobs in this Forum. It’s covered
Usual
-1998 procedure
1999- procedure
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Changing the battery will not require repairing.
MrAl
Post by MrAl »
abscate wrote: 13 Jul 2023, 18:58 Search for pairing fobs in this Forum. It’s covered
Usual
-1998 procedure
1999- procedure
Ok thanks.
BTW, did you get my PM about the optics question?
Ill be testing the key fob today.
MrAl
Post by MrAl »
Usual
-1998 procedure
1999- procedure
Ok thanks.
I found info on this forum that states you just keep clicking the fob to pair, but that can't be right, or anyone can walk up to the car and pair with it. Maybe the ignition has to be on too?
MrAl
Post by MrAl »
BEJinFbk wrote: 13 Jul 2023, 19:42 Changing the battery will not require repairing.
Hi,
That would be nice.
MrAl
Post by MrAl »
Hi,
What about if the car battery went dead and you took it out by disconnecting it completely, then put a new battery in the car.
Do you need to pair again after that?
I ask because that happened too.
Has thanked: 2199 times
Been thanked: 1852 times
You should not need to pair the fob as mentioned. Otherwise we would all be doing this on a regular basis.
As also mentioned, the same with the fob.
MrAl
Post by MrAl »
scot850 wrote: 14 Jul 2023, 10:14 You should not need to pair the fob as mentioned. Otherwise we would all be doing this on a regular basis.
Hi there Neil,
Oh great thanks.
I found out the battery in the fob was dead, 70mv, so I had to order a couple CR2016 cells.
I had CR2032 cells but they are twice as thick and so don't fit in the fob.
Test Sunday or Monday.
MrAl
Post by MrAl »
Hello again,
Ok got the new batteries today and just tested it a little while ago. It still works, hurray. :)
Have to be a little careful how you put the battery in though, make sure it touches both side contacts first then press down gently.
