850 and S/V/C70 non-turbo vacuum lines
kekec01
Year and Model: my2000 V70
Post by kekec01 »
abscate wrote: 12 Nov 2017, 17:08 You’ve got air in the hydraulics. It can be tough to get out. Perhaps a power bleeder might help?
I thought about that also, but how is it possible to get air in the hydraulics? I personaly bleed the brakes as a step 1 along with my son, he pumped the pedal and I was bleeding the brakes, I spend about 1 liter of fluid or more to be sure old fluid went out, and I saw the difference between old and new fluid. And there were no bubbles. The car start to brake better but it wasn´t the solution of my problem. That was a few months ago. Then my mechanic bleed it one more time a month ago with the calipper job, but I don´t know what method he used, I don´t think he has power bleeder. And one more question, what is the difference between standard home bleeding with brake pedal pumping and power bleeder? Isn´t that the same thing, only with the power bleeder is easier procedure? Thanks for all the replies guys :wink:
kekec01
Post by kekec01 »
wizechatmgr wrote: 12 Nov 2017, 18:13 May also wish to debate reverse bleeding if all else fails. Commonly performed on motorcycles so YT should have videos on it.
That is interesting, I never heard of that. I will check YT, sound a bit complicate, who knows :wink:
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Basically with reverse bleeding first you bleed all the lines out so that you have clean fluid coming out at all of the bleeders - if you can get any out - then you pressurize brake fluid at the bleeder and send it back towards the master cylinder. It may be able to get air out that isn't coming out any other way BUT if done on dirty fluid, you could cause damage to the master cylinder or ABS valve assembly, or both.
This is un-commonly done on a "dry" motorcycle master cylinder as a last ditch effort where you can't get any fluid to come out of the lines even though the reservoir is full and you've pumped the brake to no avail.
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
Thank you, Erik. Very useful for my 98 V70 non-T.
All U.S. market models.
All running and on the road.
kekec01
Post by kekec01 »
Vacuum hose is in good condition so I will try to bleed one more time by Vida instructions, then, if that wont help reverse bleeding.
Paul-93-850
Year and Model: 1993 850 non-turbo
Post by Paul-93-850 »
My 1993 850 non-turbo has a different diagram 3517199 . I'm just starting to trace hoses and #2 is different, it's a short hose connecting right next to the large PCV hose on the throttle body.
Paul-93-850
I replaced the rubber ends on the small vacuum hoses using pieces from a roll of vacuum tubing that I had sitting around. I cut the bad rubber off carefully with a razor blade and pressed on new ends. Also replaced the vacuum tree and o-ring. Runs good now.
Vacuum tubing package says 5/32 x 6ft (4mm x 1.83m)
RISC
Year and Model: '96 850, '99 S70
Post by RISC »
Can #2 and #6 be removed and capped off if the preheater is removed?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
RISC wrote: 23 Jun 2018, 18:03 Can #2 and #6 be removed and capped off if the preheater is removed?
Yep, good thinking.
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Bots like vacuum lines. Interesting.
[Sold] '97 S70 T5
