2004 S60 Troubleshoot heat soak ECM, BCM, CEM, & TCM Topic is solved
This topic is in the MVS Volvo Repair Database » Troubleshoot Heat Soak ECM, BCM, CEM, & TCM
GDiode
Year and Model: 2004 V70 NA
Post by GDiode »
I had the same issue with my wife's "03 XC70. After paying $600 to Xemodex to have the DIM rebuilt 3 months ago and buying the car for $1600 2 months before that I wasn't able to fork out another $500 to have the CEM rebuilt also. I was getting the same symptoms: ie 'Brake failure' message; check engine light on; AC stops running; cruise control stops; a couple of times if I didn't stop and turn the car off and back on the transmission clunked. I got the DeOxit contact cleaner on Amazon and pulled each of the black fuse boxes/relays out of the CEM spraying the metal tab connections with the DeOxit, letting them dry a couple of minutes then reinserting them into the CEM. My original plan was to spray the connection that goes into the CEM. But I couldn't figure out how to remove the wire harness (and I was running out of light in the day and would have to be up at 1:30AM to start my day (got to love the bread business). I don't know if the metal tabs were not making good contact and so breaking the continuity in the system?
It has been 3 weeks and I have not had the problem again. It had been acting up almost daily. So your my trying the DeOxit early in the process seemed to do the trick. So far. Thank you for the DeOxit suggestion.
I do plan on adding the small computer fan that mrbrian200 posted about to keep it cooled down.
Shannon
'96 855 NA 269,000
'94 854 Turbo 162,000 rebuilding the head after a burned valve
'95 854 Turbo parts car
'03 V70 XC 142,000
'04 V70 NA 230,000
'04 S60 NA 152,000 oldest daughter's car
2005 Mazda 5, 5sd 163,000
2001 Excursion 7.3 power stroke 135,000
