96 850T5 Hard restart after engine is hot in hot weather.
- Has thanked: 316 times
- Been thanked: 531 times
I’ll have to dig around for the part number, but I found one at NAPA that fit.
redbeak1
- Year and Model: 850t5 1996
- Has thanked: 7 times
- Been thanked: 2 times
Seems like a hard part to find. I checked with FCP, my Volvo dealer, Volvo parts webstore and none of them have a check valve. But IPD does have a kit that replaces the purge valve, check valve, electrical connection and hose. It's on back order so now I have time to continue troubleshooting. I will keep checking electrical as Misha and 93forme suggested. It's been a cooler summer so far in New Jersey so hot starts haven't been so hard.bmdubya1198 wrote: 06 Jun 2020, 21:47 I’ll have to dig around for the part number, but I found one at NAPA that fit.
Show a picture of the check valve or find numbers. I may have one from partcars in my stash
Whoops, meant to put a reminder down but it slipped my mind! The NAPA part number is 058 905 291 K. https://www.napaonline.com/en/p/ATM0589 ... tcQAvD_BwE
redbeak1
Thank you, I ordered the part you suggest. It does say that it does not fit a 96 Volvo 850T5. But I assume it's working for you all this time and it can handle the heat and vacuum as the original. It sure is a lot cheaper than the $165.00 Evap kit form IPD, especially since I already have the purge valve, the hose and electrical is good. I will have the part on Monday.bmdubya1198 wrote: 19 Jun 2020, 09:18 Whoops, meant to put a reminder down but it slipped my mind! The NAPA part number is 058 905 291 K. https://www.napaonline.com/en/p/ATM0589 ... tcQAvD_BwE
Thank you again for all you help.
redbeak1
I ordered the part that bmdubya1198 suggests from Napa. If it doesn't work for some reason, I'll send you the info. Thank you very much for your offer.abscate wrote: 19 Jun 2020, 04:21 Show a picture of the check valve or find numbers. I may have one from partcars in my stash
Yeah, it's a universal part, so it didn't show that it fit these. I remember one side being a hair smaller in diameter, but that's nothing a small spring type hose clamp or zip tie can't fix!
redbeak1
Here is an update. I did end up getting a check/purge valve kit from IPD specific for the 850. The one I got from NAPA for some reason had 3 ports and very small.bmdubya1198 wrote: 20 Jun 2020, 13:44 Yeah, it's a universal part, so it didn't show that it fit these. I remember one side being a hair smaller in diameter, but that's nothing a small spring type hose clamp or zip tie can't fix!
I cut open my old check valve and the diaphragm was totally deteriorated. Like a rubber band you'd leave in your drawer for a long time.
So far, the car has started well in this very hot weather. I will need to test some more, but it seems like all of you sent me in the right direction. I would have never thought of the check valve as a cause.
Thank you all so much.
Glad to hear, thanks for posting an update!
- 20 Replies
- 552 Views
Last post by cn90
- 1538 Views
Last post by rguzz
- 701 Views
Last post by MoVolvos
- 18 Replies
- 5590 Views
Last post by regent
- 2064 Views
Last post by Bdsexton06
