FDPP #2
- Has thanked: 316 times
- Been thanked: 531 times
I don’t think it will be a problem. Worse comes to worst, you can swap your original spring over to this strut. The struts should all be the same, it’s the springs that are different. How different? Probably not much.
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
https://parts.volvocarslisle.com/a/Volv ... 53424.html
Looks like they have different struts and springs both. Since that's for AWD, and I only have FWD, will the travel be the same between to two? I'm not trying to be picky, just trying to be safe. I already know what I have now isn't safe.
Travel is likely the same, it's probably just a little stiffer. I know for the XC90, for example, they just superseded the standard strut with the sport version. The fact that they did that shows that there likely isn't a huge difference in the PNs.
Especially considering that it's used, it should most likely be no problem at all.
No worries about being picky, I understand the concern! Volvo had a lot of different options for P2s, more than I knew about. One of the P2 experts could probably chime in on this, but I'm not totally sure about the differences.
- Has thanked: 2861 times
- Been thanked: 1332 times
Guys, I'm sorry I didn't read this through. I missed this post entirely.- Pete - wrote: 02 Aug 2020, 21:21 Turns out I was wrong.
8667253 A.
Does have spring, spring seat is good, top bearing plate is good.
I don’t know what shipping will run you, but you can have it (and the LSM) for the cost of shipping.
Pete, I sent you $45 on PayPal to cover these shipping costs. Please let me know if it's more than that.
Thank you so much!
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
matthew1 wrote: 05 Aug 2020, 14:26Guys, I'm sorry I didn't read this through. I missed this post entirely.- Pete - wrote: 02 Aug 2020, 21:21 Turns out I was wrong.
8667253 A.
Thank you so much!
Shipped! Should all be there by Friday/Saturday.
Thanks Matthew!
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- gnalan
Thank you Pete, Matthew, and everyone else on the forum for your help. We both truly appreciate everything.
- gnalan
LSM arrived today, and I installed it in about 5 minutes. All is working with the lights now. I can even access the hidden dtcs menu now. Thank you Pete!
Quick question about the LSM. My original one doesn't have a fuel button on it, just the rear fog lights button. What exactly does the fuel button do, and will it effect anything having a different LSM?
- - Pete -
My pleasure!
That’s only on the higher end models. It is only to be used once your fuel light comes on. It transfers an imaginary 5 gallons from your auxiliary fuel tank to your primary.
It just unlocks the fuel door.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- gnalan
I can see where the locking pin is for the fuel door, and I'm assuming a previous owner didn't know that it locked, or couldn't figure out how to unlock it, so the tab that would lock it shut, on the door itself, is broken. The button would be a nice feature, but it wouldn't really do me any good now.
I'm just thankful the LSM works, even if it does have an extra button on it, and I can drive in the dark now when I need to. I can also read the dash now, and the radio too, so those are just an added bonus.
I will update the thread again when I get the strut you sent me, and swap it with my bad one, to let you and everyone else know if it works out ok or not. I'm hoping it does.
- Been thanked: 4071 times
Nice.....- Pete - wrote: 06 Aug 2020, 14:58 My pleasure!
- 2711 Views
Last post by YYC850
- 29 Replies
- 4118 Views
Last post by foggydogg
- 1328 Views
Last post by volvolugnut
- 641 Views
Last post by rcherry506
