Vida CEM swapping
gavik
- Year and Model: 2006 xc90
- Has thanked: 21 times
There is also no way to edit the profile, the edit profile button does not work, and the vin decoder does not workdikidera wrote: 14 Dec 2025, 13:56 What vehicle profile did you select? Also go in App Logs and see if anything was written there.
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
Thanks for this, I will begin investigating now, because I personally didnt get these issues with my own profile. For sure there is some error in the logic. The profile builder will work though.
dikidera
Please test this new version. It should have fixed the issues, but most importantly, verify when the parts catalog loads that its data is 1:1 with the real vida. What is weird in your screenshot is that the vehicle shows 5 profiles, but on my android-vida I only get 3. What region is that?
- android-vida_fix.zip
- (10.61 MiB) Downloaded 17 times
gavik
I'll try to check in a few days, as I don't have access to a computer right now to build the APK.dikidera wrote: 17 Dec 2025, 10:05 Please test this new version. It should have fixed the issues, but most importantly, verify when the parts catalog loads that its data is 1:1 with the real vida. What is weird in your screenshot is that the vehicle shows 5 profiles, but on my android-vida I only get 3. What region is that?
S40cem
- Year and Model: 2006 s40
- Has thanked: 1 time
Hello everyone. I have a 2006 Volvo S40. I’m trying to find the PIN code for my CEM module: 30728906, “I am using the program code from this link:https://github.com/vtl/volvo-cem-cracke ... me-ov-file But unfortunately, the code cannot be found.Could you please advise what other options are available?
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Assuming the cracker hw works and can make progress, it is just pin that fails to be found... Try this version, it works better for P1 CEMs: https://github.com/cmolson/volvo-cem-cr ... e/one_passS40cem wrote: 19 Dec 2025, 06:56 Hello everyone. I have a 2006 Volvo S40. I’m trying to find the PIN code for my CEM module: 30728906, “I am using the program code from this link:https://github.com/vtl/volvo-cem-cracke ... me-ov-file But unfortunately, the code cannot be found.Could you please advise what other options are available?
If it still fails, try to change the shuffle order for your CEM p/n, last digit in this line: https://github.com/vtl/volvo-cem-cracke ... er.ino#L82 Four shuffle orders are available, 0 to 3.
S40cem
Thank you very much for your reply.
I tried different order settings from 0 to 4, but every time the software reported that the PIN code could not be cracked. Each attempt produced a different 6-digit result.
vtl
Try to remove this line: https://github.com/vtl/volvo-cem-cracke ... .ino#L1322 (and similar line in one_pass branch, try it there, too). Also show a good picture of your hardware?S40cem wrote: 19 Dec 2025, 08:05 Thank you very much for your reply.
- 9286 Views
Last post by RickHaleParker
- 9240 Views
- 27 Replies
- 28624 Views
Last post by cn90
- 10720 Views
Last post by jonesg
- 5857 Views
