I tried deleting line 1322, but unfortunately the PIN code was not cracked.vtl wrote: 19 Dec 2025, 08:17Try to remove this line: https://github.com/vtl/volvo-cem-cracke ... .ino#L1322 (and similar line in one_pass branch, try it there, too). Also show a good picture of your hardware?S40cem wrote: 19 Dec 2025, 08:05 Thank you very much for your reply.
I tried different order settings from 0 to 4, but every time the software reported that the PIN code could not be cracked. Each attempt produced a different 6-digit result.
Vida CEM swapping
S40cem
- Year and Model: 2006 s40
- Has thanked: 1 time
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Is it an OBD cable? CAN uses a differential signalling, the wires need to be twisted.
If you crack your CEM on the bench (outside of car) you need to terminate CAN bus - the yellow jumper on your CAN bus shield.
gavik
- Year and Model: 2006 xc90
- Has thanked: 21 times
Can you post the finished APK? I can't compile it.dikidera wrote: 17 Dec 2025, 10:05 Please test this new version. It should have fixed the issues, but most importantly, verify when the parts catalog loads that its data is 1:1 with the real vida. What is weird in your screenshot is that the vehicle shows 5 profiles, but on my android-vida I only get 3. What region is that?
Hi all,
Thanks for your great job here.
I made the sketch with a Teensy 4.0 but I'm failing to connect to the HS CAN on my MY04 XC90.
My CEM is a CEM-B, part number is 08688513 so it requires a K-Line activation. I use some transistors to send the K-Line keep alive message.
I managed to see the LS CAN but not the HS.
Any help would be greatly appreciated!
Merry Xmas to all!
Gilles
Merry Xmas to all!
Gilles
vtl
Arduino EEPROM reader, can find in this thread. Need to take the CEM out and solder a bunch of wires.Dragoz001 wrote: 25 Dec 2025, 09:09 Thanks for your fast reply!
Oh. I thought it was... This ref is listed in the code.
Any other solution?
Dudde
- Year and Model: 2005 V70 and more
- Has thanked: 17 times
- Been thanked: 17 times
Use OM to get pincode through OBDDragoz001 wrote: 25 Dec 2025, 09:09 Thanks for your fast reply!
Any other solution?
- 9536 Views
Last post by RickHaleParker
- 9676 Views
- 27 Replies
- 29942 Views
Last post by cn90
- 11275 Views
Last post by jonesg
- 6376 Views
