- Has thanked: 317 times
- Been thanked: 531 times
Wow, that seat looks great!
- Has thanked: 2866 times
- Been thanked: 1332 times
Very cool Dash Viking, Dirk. That seat is amazing, I agree.
Scranton? Did you say hi to Dunder Mifflin?
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Just catching up here -
1. Sveedy & bmdubya : What do you use for smoke? I tried to get some oily rags to smolder. What psi do you use? I used a gallon paint can. Mistake I made was choosing clear tubing that got soft when it was hot - it kinked, pressure built up for a second, and blew the lid off the can!
2. Groupil : Nice driving to hit the mileage exactly!
3. Yanga : You don't want a Highlander. Your kids will grow up sad.
4. Chuck W : That task might qualify you to be a rocket scientist.
5. 850LPT : I love the Viking! We have a stuffed Bison from Yellowstone, who wears a bandana, and he goes on adventure trips with us.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I ignited some charcoal and sat it on top of a crumpled piece of foil then through cardboard pieces on top. I ran a roadside inflator through the paint can. Worked great.
I have an old sock (rag will also work of course) that I soak in mineral oil, then a pen style soldering iron (the $3 harbor freight one) glued to the lid. Looks hilarious, but it does the job! Air pressure comes from a bicycle pump, but super low regulated pressure is ideal. That way you get constant pressure into the system. Most people recommend a propane regulator set to like 1-2 PSI.
I’ll have to post a picture if I think about it tomorrow.
Finest paper in the industry!matthew1 wrote: 14 Mar 2021, 19:36 Very cool Dash Viking, Dirk. That seat is amazing, I agree.
- Has thanked: 1614 times
- Been thanked: 4078 times
The have a fax machine,that receives faxes.bmdubya1198 wrote: 14 Mar 2021, 23:37Finest paper in the industry!matthew1 wrote: 14 Mar 2021, 19:36 Very cool Dash Viking, Dirk. That seat is amazing, I agree.
From the future.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I used piece of old towel ( apx 3" x 3" ) that I discovered smouldered quite well. Could have added oil to make it smoke better but it seemed to burn well without it. About 5 psi or so. Kind of hard to to use my compressor at that low of a setting but it worked. Opened oil filler cap and pulled dipstick so as to not have pressure build up. Might work better with cap on, but loose, so more smoke can get into the intake but not sure about that. First time I have ever had to do it.
1999 V70 GLT
1999 V70 GLT
- BlackBart
Yeah, I borrowed a compressor and it's hard to get the psi that low, or steady. Roadside inflator is an idea!
Regarding my Highlander snark - here's the reason...I saved this funny long ago and drag it out occasionally.
or....if you get tempted by miniature vans, I have this handy public service announcement to go with it.....
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
Changed my oil, swapped my tires (snow vs rest of year), cleaned my cabin filter and tried to debug my random stalling issue.
When I went to log my oil change, I discovered that the last time I did a change, it was 8/2019. Couldn't believe that. 5000miles but 1.5 years.
-A
-A
