Axle is stuck:( Topic is solved
5rivers
Year and Model: V70 1998 T5
Been thanked: 14 times
Re: Axle is stuck:(
Post by 5rivers »
Have the seals, am wondering now if I should start the car and go through each gear to eliminate any noise from the transmission.
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
5rivers
Post by 5rivers »
I don’t think I want to switch places with you scot850! Your dash looks like any amount of glue would not be enough! But you have made some amazing repairs elsewhere, so maybe there’s hope! Good luck with that project!
5rivers
Has thanked: 1848 times
Been thanked: 1710 times
I am being sneaky and using the significantly better 'spare' from the stash. "I had a feeling about this", as a Jedi would say! :D
The 'spare' has only one slightly cracked mount and a small repair needed on one screw mount for the upper to lower dash screws around the glove box opening. I will reinforce it and weld it.
Thanks for the encouragement!
More importantly, did you manage any progress yourself today? I don't think anything should stop you doing what you are suggesting, but just watch for trans oil loss. The fluid does not typically drain when sitting, but when moving it will splash out the axle holes in the trans.
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
5rivers wrote: 16 May 2023, 11:27 Have the seals, am wondering now if I should start the car and go through each gear to eliminate any noise from the transmission.
Unless others have a reason it would hurt something I would. I would want the reassurance the previous grinding noise is not coming from the transmission.
08 C702.5T (sold)
The non-Swedes:
5rivers
Post by 5rivers »
I did start the car and was able to shift into each of the gears without any problems.
Got the drivers side axle in with a new spring clip and seal.
Still need to put the tire back on, lower that corner of the car, torque the axle nut before I can restart the car to test the transmission/axle for any grinding noise.
5rivers
5rivers
Post by 5rivers »
I managed to get the tire on and torqued the lug nuts and the axle nut. Then raised the car again so I could test the transmission. There is no problem shifting through the gears, but when I move the shifter to park, there is noise - like the beginnings of a grinding noise. I can not shift into park with the car running. I am reluctant to force it.
Thoughts?
Will try to get a video sound recording and paste it here.
5rivers
5rivers
Post by 5rivers »
Here’s the video/sound recording of my attempt to get car into park.
IMG_0247.mov
(40.56 MiB) Downloaded 53 times
Appreciate your thoughts on what might be causing this noise. Thanks in advance!
Now, to clean up the mess under the transmission!
5rivers
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
5rivers wrote: 17 May 2023, 13:05 Here’s the video/sound recording of my attempt to get car into park.
IMG_0247.mov
Just to make sure the obvious is asked... You brought the axles rotation to a complete stop before you attempted park, correct?
5rivers
Post by 5rivers »
I installed the drivers side axle, started the car and pressed down on the brakes before shifting into and out of each gear. But when it came to shifting back into park, the noise started.
Not really sure what to do.
Still need to install the passenger side axle, but am uncertain if that will cause more problems/damage.
Appreciate your help!
5rivers
