A $100 '99 V70 GLT Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Well after receiving the valve stem seals a few days ago ( mucho Thanks abscate ), I was able to assemble and install the head.
I'm feeling like it's all down hill from here. Fingers crossed.
Lifters sitting in oil awaiting install
1999 V70 GLT
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Wow, you’re good!
Sveedy
Post by Sveedy »
Thanks for the vote of confidence B.B. But some of this is a first for me. And then there is this reoccurring thought that this all might turn out to be an epic failure if I get this started and discover a rod knock etc. :( Then I'd really be in a pickle.
But like a lot of historical screw ups, " Well we've come this far, so we might as well keep going. "
1999 V70 GLT
BlackBart
Post by BlackBart »
You are correct!
BlackBart
Post by BlackBart »
abscate wrote: 31 Mar 2025, 09:22 Its NY, NJ, and the South. We dont really differentiate between TX and AZ.
Send me that address!!
It's Montana, Wyoming, Colorado, New Mexico, Arizona, and all those little Eastern States over there.... :wink:
Has thanked: 1610 times
Been thanked: 4068 times
BlackBart wrote: 07 Apr 2025, 10:54
Just don’t try to sneak Iowa in there. That’s just potatoes.
Montana doesn’t even know it’s a state. It’s Grizzlies and Wildcats.
BlackBart
Post by BlackBart »
More cows than people, and as you can see they all vote the wrong way. And it's hard to pull those little levers if you're a cow.
Sveedy
Post by Sveedy »
So I was looking at the fuel line connector at the fuel rail and I'm wondering how this thing seals. The 850 has no such thing.
It looks like there is an o-ring in there, but how do you service it ?
Also have this connector on a pigtail that comes out of the harness at the alternator. It looks like it needs a male plug, but I haven't seen one looking for a socket. Is it maybe the ECT connector ? I'm still missing that part.
1999 V70 GLT
The hard fuel line slides right into that bell shaped connector and seals on those O-rings
It’s right above your index finger holding the ECT connector
THat is the ECT connector for the 99 00 years
Sveedy
Post by Sveedy »
I'm guessing that the previous owners didn't use distilled water or a premix for the coolant system.
Now I'm thinking that maybe I should try and flush the block out before I install the new pump. Maybe just stuff a hose in there and give it a blast... ? After installing the cam cover etc of course.
1999 V70 GLT
