I have used a T-20, cocked at an angle and being very gentle on the torque, to get the torx screws out that I can't get a good straight bit on.
Climate unit blower replacement
- Year and Model: Many Volvos
- Been thanked: 76 times
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
That's a really good tip, unfortunately...I don't have a T-20. I think I might saw off the end of the T-25 like I did with my T-30 when I had to remove the airbag from the steering wheel. On a side note, aside from getting hung up on this last screw, everything else has been really easy; thanks a lot for the write up.
polskamafia mjl
Had my dad cut off the handle to the T-25 and I managed to get the blower out. It was a bear to weave it past all of the wires. Any advice on putting it back in? Lee, I was curious as to how your blower held up after the WD40 treatment?
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
World's coolest tool for tight spots:
http://www.spectools.com/spec.htm
Skewdriver - Ask for it by name...
So far so good.Lee, I was curious as to how your blower held up after the WD40 treatment?
polskamafia mjl
That's good. I've got another question, however. I've got the screw off and the pwer connector out but the motor won't slide out of the housing. Anyother advice on how to get it out? I'm afraid to pull too hard on the plastic cage because i don't want to break it.
I had the same fear so I just sprayed the crap out of the front bearing with the blower cage still on using a tube nozzle on the oil. Others claim you can tap the shaft out by supporting the blower cage from the sides but I was not so bold as to even try after the first attempt where the blower cage appeared to me to be well and truly press fitted on.polskamafia mjl wrote:That's good. I've got another question, however. I've got the screw off and the pwer connector out but the motor won't slide out of the housing. Anyother advice on how to get it out? I'm afraid to pull too hard on the plastic cage because i don't want to break it.
polskamafia mjl
Are you saying that you didn't even remove the blower motor from the housing? Or were you talking about taking the cage off the motor itself?
polskamafia mjl
NVM, I just got it out. I pounded it out from the back through the hole that the t20 screw goes into. Came out just fine and I used WD40 on the bearings. I'm going to let it sit over night and I'll put it back in tomorrow.
patrioty3k
- Year and Model: 1995 850 Turbo Wagon
Great write-ups and pics,i'm planning on removeing the noisy blower unit soon,so if i read correctly,you should disconnect the battery?I have the climate control system on my'95 850 turbo s/w.Are there sensors under the dash or somewhere that control the temp? Thanks
1995 850 Turbo S/Wagon,Alpine head w/Sirius Sat. Radio--"OCTANE" power!
200K $400 Sleeper...nuff said!
- 1339 Views
Last post by Jepc
- 2439 Views
Last post by DrDan
- 2162 Views
Last post by Jumbobazman
- 2529 Views
Last post by nsomlai
- 1141 Views
