Just wondering if the alternator could be causing a intermittent malfunction in the electrics which produces a drop in revs.
Guess it wouldn't be that hard to swap out with a known good one; just another item to eliminate from the (growing) list
Very minor issue but I'm stumped
precopster
- Year and Model: Lots
- Been thanked: 128 times
JRL
- Year and Model: Several
- Been thanked: 16 times
Nope
Charging system has been checked, car has new cables too.
remember it only does this when completely hot(Not just the water but the oil, at least a full 20 minutes after starting the car).
When cold and up to the first 15+ minutes, the car runs 110%
fields 100
- Year and Model: s 60 T-5 2013
You have previosly mentioned, that you are running rich and the MPG became not so good.It is possible, that ECT thermistor is malfunctioning and briefly enough to not set the code.I check my ECT with a graph (temp-resistance) at the cold and then thoughout the temp. range as the engine warms up.There is also specified voltage from the ECU to the ECT on the cold engine.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
My mysterious idle dip -- warm engine, at stop light, idle drops 50-100 rpm then comes back up -- appears to have disappeared after I replaced the front 02 sensor.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 17 times
- Been thanked: 35 times
Hey Jim- I second the ECT as well....worth taking a look at that- they aren't very expensive to replace either.
- 1925 Views
Last post by 93Regina
- 449 Views
- 571 Views
Last post by vtl
- 24 Replies
- 4535 Views
Last post by bmdubya1198
- 587 Views
Last post by 2012
