Go to Full editor, then add attachments, load em and post em
Then write a memo to Matt that drag and drop doesn't work.
Head gasket job. Won't start
- Been thanked: 4068 times
- Has thanked: 311 times
- Been thanked: 817 times
Check on the side of the head near the passenger side firewall, where the water pipe connects. Pesky and inaccessible, the paper gasket often gets folded or dislodged causing a leak there.Kazbear wrote: 09 Feb 2018, 12:41 ... Now I have a major coolant leak, but I will track that down. Seems like it's from the water pump. ...
Kazbear
- Year and Model: 2000 v70
Ugh! Yeah, that was a painerikv11 wrote: 09 Feb 2018, 13:33Check on the side of the head near the passenger side firewall, where the water pipe connects. Pesky and inaccessible, the paper gasket often gets folded or dislodged causing a leak there.Kazbear wrote: 09 Feb 2018, 12:41 ... Now I have a major coolant leak, but I will track that down. Seems like it's from the water pump. ...
Kazbear
Well, this is fun.erikv11 wrote: 09 Feb 2018, 13:33Check on the side of the head near the passenger side firewall, where the water pipe connects. Pesky and inaccessible, the paper gasket often gets folded or dislodged causing a leak there.Kazbear wrote: 09 Feb 2018, 12:41 ... Now I have a major coolant leak, but I will track that down. Seems like it's from the water pump. ...
It would appear that I have now stripped one of the threads in the head at the pipe.
Do you think I will have any luck with some kind of thread repair kit? Helicoil?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I like these:
- loosenut
- Year and Model: 2006 V70R
- Been thanked: 7 times
ok so in case anyone needs this trick...
take the bolt and hold it with a pair of vise grips on the head.
take a sledge hammer and smash the threads flatten them a bit on both sides so then you have an "oval" type bolt.
then this new bolt will cut new threads use the proper torque and walaa....
Lol at the drama of it all ... but nice tip!
- 1304 Views
Last post by goldmandan
- 1314 Views
- 13 Replies
- 967 Views
Last post by Roger_850T
- 25 Replies
- 1585 Views
Last post by Maestrours
- 18 Replies
- 5940 Views
