Diary of a 17 y/o with an 850
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
I need Bosch numbers...under the Bosch logo...i can't see them.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1611 times
Been thanked: 4075 times
Heinz 57 were only sold in Pennsylvania, I think
:D :D :D
misha
Post by misha »
shihabafi wrote: 16 Jul 2018, 15:36 ...Also, the radiator fan spins from as soon as I turn my key to II (before cranking), all the way until a good 3-4 mins after I shut the engine off... And ideas why?
Your AC is ON...turn it off(5th picture from the 1st post). :)
About why it runs when engine is off....it is usually ECT.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
misha wrote: 18 Jul 2018, 07:58
shihabafi wrote: 17 Jul 2018, 16:54 ...Is now a good time to mention that when we pulled out a Camshaft Position Sensor (for my most recent job), we pulled one out of a non-turbo and it started smoking up. So we matched up the part numbers and noticed they weren't the same. So we went back to the junkyard to find one that matched our part, and lo and behold, it belonged to a turbo-ed engine. We were also confused, but hey, the numbers matched....
Did somebody payed attention to this post?
To me..it sounds like it WAS a turbo car somewhere in the past....and converted to a non turbo.
That would explain why it have M4.3 in a '95 or M4.4 for which i would need Bosch numbers from ecu for confirmation.
The turbo and non-turbo use the same cam sensor. There is an old style (black plastic cap) and a new style (all metal) but they are completely interchangeable, I have swapped them around myself etc. This is just a coincidence that they found one on a turbo car that looks the same.
It's not a unicorn, it's a horse.
shihabafi
Year and Model: 1995 850 Wagon
Has thanked: 50 times
Been thanked: 8 times
Post by shihabafi »
misha wrote: 18 Jul 2018, 12:21
turned it off since then lol don't worry!
erikv11 wrote: 18 Jul 2018, 12:21
</3
Also, my engine makes this clicking noise that randomly appears and disappears... The clicking is in tune with the rpms of the engine... Should I be concerned?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Probably that’s just the notoriously loud fuel injectors.
Also -> Amazon link
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
His VIN says it came out of the factory as a NA. The build may of started off as a turbo then got a NA ... because they where short on turbo engines ... the Heinz 57 concept.
Ticking like a sewing machine? If so, most likely a lifter(s) getting weak or injectors.
If it sounds like somebody smacking with a hammer, be concerned.
Active
Past
misha
Post by misha »
shihabafi wrote: 18 Jul 2018, 14:24
turned it off since then lol don't worry...
I hope that you understand this correctly....cooling fan will work all the time when ac is ON...key in position II and while running...but it must NOT run when engine is turned OFF...unless ECT is faulty.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Dmck
Has thanked: 2 times
Been thanked: 3 times
Post by Dmck »
Ticking can also be the cam hitting the lifter. It's possible for the hole in the head oil travels through to lube the lifters gets clogged and then the cam hammers on dry lifters creating that tick...
I’ve noticed my 99 fan will run on if the MAF is disconnected.
