2005 XC90 T6 Executive Project Car.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
RickHaleParker wrote: 23 Aug 2019, 13:02
bmdubya1198 wrote: 11 Aug 2019, 22:12 Is that symptom of transmission failure? Hopefully it’s something that can be solved with a couple drain-and-fills. Those 4T65s aren’t known for their durability.
It simmered down after I got the engine running right. Its like it could not make a decision with all the ECM codes.
Glad it seems to have cleared up!
I just tagged my '03 S60 today, and that has a BAD flare into 3rd gear. Hopefully an updated B4 servo and drain & fill will knock that out.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
On the shift lock, the books say one of two things worn ignition lock or interlock cable.
The lever with the yellow locking sleeve not moving all the way forward. Weak spring on the ignition lock end?
I slid the interlock cable at the yellow locking sleeve . Key goes back to POS 0. Shifter will come out of Park with no effort. Down side the interlock is not working. I can remove the key in any gear and the shifter can be moved when the car is off. Still, it a quick fix until I have time to track down the root cause.
Clanking from under the car. Strut mounts are broken.
Active
Past
RickHaleParker
SuperHerman wrote: 22 Aug 2019, 16:55
If you can get there this route I strongly recommend it. Drilling out and replacing rivets in plastic never works out well.
Do some searching for pictures or videos on the alarm module. They appear to be all the same - (the set up for the S80, XC90 and XC70 I did were the same). That will tell you what you are up against.
Getting the liner out of the way was not too hard.
1. Removed the fasteners on the front edge.
2. Removed two nuts on the backside.
3 Drilled one rivet on the plastic bracket holding the liner to the molding.
4. Pulled the backside over the bolts then down until front edge slipped past the plastic bracket.
5. folded the liner back and out of the way.
Cut a slot on the security bolt. Could not turn it with screwdriver. Cut a edge on the security bolt, then used a hammer and chisel to back it out.
Disconnected the alarm siren and the sunroof came back to life.
Both leads to the battery are burnt in two. Board looks cooked.
Active
Past
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Board actually doesn't look too bad. If you have a VOM and a soldering iron you may be able to save it. Depends if you want to do the work.
Start by cleaning it with some alcohol and a Q-tip, but be careful not to further damage any of the traces. Once it is cleaned up use your VOM and check if the circuit path is still working. By this I mean pick a spot and follow the trace and check for continuity. Do this for ever trace that looks suspect. If you find some broken ones either use a very small wire and bridge it or just use solder and bridge it that way.
I forget what the battery voltage on it is (7.2V), but that should be easy to dig up. You can power it with regular batteries to see if the unit works (not sure if you even need batteries for testing). If it works then figure out how you want to power it (plenty of write ups and ideas on the forum). There is a charging circuit for the NiCads so don't leave non NiCads hooked up for too long). Get some epoxy or some use clear nail polish and seal up your repair and any traces (very thin layer to cover the electronics from air/corrosion).
You can buy a used one with a warranty and then cut that open and swap out the batteries - but make sure it works before you cut it open. Batteries last from 6-10 years and then start to leak. A new one can be had for about $250. I have gone both routes - the used one was just starting to leak, but had no board damage. The ones I have opened up from my cars were completely rotted with nothing to work with trace wise.
bmdubya1198
Good info. I think the alarm siren on my 01 S60 was causing a small battery drain. I pulled the fuse yesterday and it didn’t struggle to start today.
I might try to pull it out and check it out once I figure out the VVT issue I’m dealing with.
RickHaleParker
SuperHerman wrote: 10 Sep 2019, 19:28 Start by cleaning it with some alcohol and a Q-tip, but be careful not to further damage any of the traces.
It is gone. Started to clean it and one of the surface mount transistors lifted clean off the board.
Eric Vo-Vo has some tested used units for $75 in their eBay store ($129 on their website) comes with their Lifetime Warranty. I might go that route.
Active
Past
SuperHerman
Used is a good plan, but I would still open it up and replace the batteries. That way you won't have to touch it ever again (at least for a long while). Bottom line is the NiCads leak - it is normal. Warranty or not, you still have to rip the thing apart. Only concern is you open it up, it is rotted out (but working) and Erie won't honor their warranty. I suppose you could call them and tell them your plan.
RickHaleParker
SuperHerman wrote: 10 Sep 2019, 19:28 There is a charging circuit for the NiCads so don't leave non NiCads hooked up for too long).
The battery pack Rating: 7.2V 150mAh.
The 3 cells are N2H280, they are Sealed NiMH (Nickel-Metal Hydride). Which is a good thing because they been phasing out NiCad (Nickel–Cadmium) for the last 13 years, Cadmium pretty toxic.
Google "Volvo N2H280" then run through the links. You will confirm it.
Active
Past
RickHaleParker
The four Vibration damper bolts are stretched like head bolts and they are not supposed to be reused.
I cannot find the bolts, part number or any other information on them.
Active
Past
SuperHerman
I have always reused them - did not know they were single use. Torque is not that high for the size of the bolt and they are not AL.
On the batteries - not sure if they switched to NIMH from NiCad - but if they always used NIMH they will leak.
