Corrupt Canbus, xemodex said good luck Topic is solved
imac
Year and Model: 1999 S80 T6
Post by imac »
I've driven 5000km since the swap, and it's been absolutely flawless it's truly a joy to drive.
I decided to swap every last module, my worry was one of the other modules was shot, and causing the modules on the high speed can bus to work overtime and eventually fail themselves. I feared if I only swapped the CEM, ECM, TCM, ABS, and REM, I'm sure it would have started and ran... but if the climate control, or door module etc was in fact damaged, it could fry everything all over again. For that reason I wasn't up for swapping one at a time to see what's vin locked or not. And yes, when plugged into vida it does show a different vin and a different year, but I could care less. There are emission tests in Canada yes, but I live far enough north I am exempt, and worse case I do have the ownership for the new car + vin.
So game on, I made just enough room in the garage fit her, and parked the parts car outside in the snow. All said and done, it was a really easy job, only a handful of tools needed, plus a couple hours of my time.
The intake tube where it met the ETM looks like it's been leaking for a while! Related? Dunno, swapped for near mint one off parts car. There was a mass of oily crap all over the ETM, it's been like this for some time.
I had to die grind the top of the ignition bolts in the car to get it them out, took 5 minutes. I got one bolt out, the other I drilled and tapped.
I slammed in these modules, and she fired right up.
Conclusion: If you get the BRAKE FAIL message, just cut to the chase. Find a low km donor car for $800 and swap away. I wish I'd done this months ago. Thanks for the insight during the process, Cheers
Has thanked: 1609 times
Been thanked: 4065 times
imac wrote: 13 Dec 2019, 12:27 Here goes nothing...
I pulled the CEM, TCM, ECM, ABS, ETM, DDM, PDM, PSM, ISM, SWM, UEM, REM, SRS, DIM, and CCM from my donor s80,
Along with the seats as the psm is there and my driver's sips was an error that wouldn't clear in vida.
These are going in my car tonight, wish me luck :)
Was this the complete list of swapped stuff ?
imac
Post by imac »
Think so, what a chore! Worked tho ;)
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
Curious as to the OSC equipment you used. Can you mention the company? Thanks.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
imac
Post by imac »
The scope was SainSmart Mini Digital Oscilloscope DS212-2 Channels 1M 10MSa/s & i bought 1 extra probe for the 2nd channel. Worked well enough for what I had to do
andrewgabler
Year and Model: 2007 S60R
Has thanked: 1 time
Post by andrewgabler »
I'm actually convinced that this was you DIM causing this. Out of curiosity did you ever swap only the dim? Brake failure seems to be the common message it throws when the Can Network is bugged out because I think it has a the tightest "reporting requirements" for safety reasons.
