Has thanked: 1613 times
Been thanked: 4077 times
FireFox31 wrote: 18 Aug 2021, 21:01
Nevada1906 wrote: 18 Aug 2021, 19:44 While I'm reassembling the B5254T so I can actually use it in the car, I'm also building up the short block for the B5234T.
How do you car gurus know all the exacting information required to do this kind of work and have access to all of these interesting parts (old S60R engine) and tools? I'm fighting to overcome nerves to change my timing belt and you are rebuilding multiple Frankenstein engines. I'm amazed.
There are some cool dudettes and dudes here. I didn’t know Diddley about Volvo service until 2013, when I found MVS , and decided to refurb my T5 instead of dumping it
If you want to bring Green over here for an evening we will rip that timing belt and pump job in two hours, tops…..
New topic,,, Neil , I’m done with this rear caliper, where do I send it ??
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I just can't get over that amount of rust. Exactly how many years did that thing spend on the bottom of the ocean ? Eaten clear through the pin retaining hole. Go to the local junkyard here and you'd be hard pressed to find anything at all that looks like that.
Scary how the average relative humidity, coupled with a little salt, can have such an effect.
1999 V70 GLT
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Sveedy wrote: 19 Aug 2021, 09:31 I just can't get over that amount of rust. Exactly how many years did that thing spend on the bottom of the ocean ? Eaten clear through the pin retaining hole. Go to the local junkyard here and you'd be hard pressed to find anything at all that looks like that.
Yup, same here. I never cease to be amazed by the amount of surface rust on cars in the NE.
Has thanked: 2215 times
Been thanked: 1853 times
Sorry abscate, but that core doesn't work for me other than a paper weight. The 00 R has calipers unique to that model and year which are now NLA!
Which of your crusty cars is that brake on? It is scary to see the brakes that bad. It can't be one of your current regulars as you would be unlikely to allow that to happen! :o
Our calipers can get that crusty up here in Calgary but I normally grind/wire brush and caliper paint them to try to reduce the issue. The other major way to reduce this issue is just not to drive it!
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
I think this is due for replacement.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Hope springs eternal, ...
But it doesn't look any better out here than it did under the car.
I think Plan B just became Plan Only.
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
BlackBart wrote: 18 Aug 2021, 20:50
Oh well, I still have three working burners
However, now I can tell people I once dropped a Volvo crank through a stove.
Ouch. Was Mrs Nevada out of town?
So, just to clarify - you had to bring the engine inside where it’s cooler..?
Yeah, it's 80-90 out in the garage. Eff that noise, man.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
bmdubya1198
Nevada1906 wrote: 19 Aug 2021, 17:38 Damn. That was probably the unobtanium bracket, too.
I think I might even have one lying around here somewhere, but it's not fun to pull unless you already have the engine stripped down, that's for sure!
Nevada1906 wrote: 19 Aug 2021, 17:40 I know people that'd try to warranty that caliper...
Hey, if it's from FCP, they would happily accept it!
ZionXIX
Post by ZionXIX »
Does anyone know the dimensions of the front/rear hydraulic engine mounts? Trying to determine if mine are collapsing by measuring the distance from the subframe to the mounting plate.
Was on Shagg but it’s all new now. I booted this despite being warned by the PO.
I have never seen structural failure like this in any caliper. I suspect it’s a pot metal problem.
