The coils ground both through the harness and through the M6 bolt into the head, I bet both are important.
The primary side is grounded by the ECU to fire, though.
What kind of sealant for the cam cover?
- Been thanked: 4064 times
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Can you steer me towards this info? I'm not having much luck with a search.abscate wrote: 05 Sep 2018, 07:52 Extensive coil measurements on a thread - I bookmarked it in my 1999 maintenance log on the T5 Nautic Blue in that Forum area. If you pull the coil part number I have added part numbers to a lot of these threads...
- BlackBart
And what the hell are these extra bolts? Don't you hate it when you end up with extra bolts? Yike.
They are 10mm hex head, a matched pair. Not big enough to be really structural so I'm not very concerned. They happen to be the same size as the cam position sensor caps, thread right in. But I had two matching torx head screw/bolts that seemed to go there and fit perfectly.
They were in a different (unmarked) tub than the cam cover bolts and a little different. No unfilled holes on the head.
Coil hold down bolts - those are important?
Intake manifold bolts _ all in ??
- prwood
- Year and Model: 2001 V70 2.4T
- Has thanked: 9 times
- Been thanked: 22 times
The screws on my camshaft position sensor are hex, not torx, so I’m guessing that’s what those are. Not sure what the torx are.
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
- BlackBart
Oh! It just occurred to me. They are the third cam sprocket bolt on each camshaft! Don’t know why it just popped into my head. Plastic cover is on, so you’d never see it.
Glad I didn’t go out and stress it.
- RickHaleParker
- Been thanked: 977 times
Best way to keep track of where bolts go ... store them in the bolt holes they go in.
Active
Past
Past
- prwood
Interesting, your sprocket bolts are torx? Mine are all hex. Maybe something that changed in later MY's?BlackBart wrote: 09 Sep 2018, 19:43 Oh! It just occurred to me. They are the third cam sprocket bolt on each camshaft! Don’t know why it just popped into my head. Plastic cover is on, so you’d never see it.
Cars I've owned:
First time I am in a big job, I bag and tag. I put a reference number on the bag, and then write the reference number on the paper printout the VIDA procedure.RickHaleParker wrote: 10 Sep 2018, 01:32 Best way to keep track of where bolts go ... store them in the bolt holes they go in.
The hour of time this takes has always come back when I find something which I can't recognize.
If I break a fastener, I make a note so I can take the old ones with me to the store to order new.
Last and not least - when all the bags are empty, you know you are good.
- prwood
Last time I did a job with lots of fiddly bolts, I used a leftover egg carton:
I like the bag idea in theory since it would be easier to fit longer bolts and oddly shaped clips, although the few times I've used bags I end up with pointy bits sticking out and making holes.
Cars I've owned:
- 3114 Views
Last post by MadeInJapan
- 2747 Views
Last post by BlackBart
- 979 Views
- 1374 Views
Last post by Chili58
- 2226 Views
Last post by smacknab
