- Has thanked: 316 times
- Been thanked: 531 times
Aaaand the alarm is going off again. I give up.
- Has thanked: 1611 times
- Been thanked: 4074 times
Tailgate wires??
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Don't they have a way in the 98's to determine which switch/sensor is causing the alarm similar to the '99?
2023 Lexus RZ450e -66k
Yup. Fixed that wire 3 times.
I know it’s the tailgate latch, it goes off after I open the tailgate when I unlock it with the key.wizechatmgr wrote: 30 Mar 2018, 18:34Don't they have a way in the 98's to determine which switch/sensor is causing the alarm similar to the '99?
This tailgate harness if driving me nuts!
I think that’s normal function. The fob or the driver door disable the alarm, the trunk lid does notbmdubya1198 wrote: 30 Mar 2018, 18:45Yup. Fixed that wire 3 times.
Then why the heck is there a key hole there? Volvos...
They dropped it a year or two later, 1999s are special
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
did you grab the ecu by chance, sounds like stage III with a 19t and exhaust/intercooler upgrades. What about the injectors?bmdubya1198 wrote: 30 Mar 2018, 07:35 Had another good day yesterday at the junkyard. Initially I went for a couple relays, my cousin says "I'm probably not getting anything." Naturally we ended up coming home with a 19t and an S60R exhaust manifold, along with a larger intercooler (though I'm not sure the brand).
Same car he got his e-code jewels from as well as a Supersprint exhaust. I at least got an R steering wheel from it. I would have loved to get that car before it ended up there... black on black manual '99 C70 HPT coupe. The only thing that would have made it better was if it was a non-sunroof '98. Fortunately between me and my cousin we bought up all the valuables!
Current Volvos:
It's ME7, so I did not grab the ECU. I don't know what's entailed in re-coding it to a different car.FLXC90 wrote: 31 Mar 2018, 11:02 did you grab the ecu by chance, sounds like stage III with a 19t and exhaust/intercooler upgrades. What about the injectors?
It had blues, and I didn't grab them. I do plan on getting them next time if they're still there, though.
s10lowrider1994
- Year and Model: 2000 v70
- Been thanked: 3 times
New coolant reservoir and sensor (bye coolant light) and tidied up the mess of dry rotted wire loom under the top cover. Timing belt job this coming week and hoping to hit 300,000 miles shortly.
