theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Finally got around to installing my battery tie down! Also took the time to remove some oxidation from my battery terminals.
Also, you know, poking around the engine bay and checking stuff out. I realized this bolt (14mm, lower torque bracket bolt) was loose....
sheesh... :roll:
I wonder if this is why I've had a rough/harsh engine shut-off rumble for such a long time.
I had to replace this bracket when I broke it two years ago. I wonder if I forgot to tighten this or if it worked itself loose... Will definitely check out later.
Retired:
2015 Volvo S60, T5, 85K
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Tightened the wiper blade nut on the T5-R. Again. Exhausting job, wiped me out.
About a month ago I noticed 3 out of 4 CV boots leaking grease on the 96 855, so I parked it. This weekend I finally got it into the garage and the axles pulled. Will try to chip away at re-booting them this week. One of the outers is still intact but I will just remove the outer CV's on both sides do all 4 of boots.
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
My second attempt at replacing a fuel filter was far more successful, with no broken lines and minimal spillage. The bracket took some fiddling with to reattach but otherwise pretty quick.
Motivated, I tackled the right sway end link. It did not go as smoothly.
'00 V70 fuel filter
'00 V70 fuel filter
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
bmdubya1198 wrote: 30 Mar 2018, 20:43 Then why the heck is there a key hole there? Volvos... :roll:
Believe I used to encounter the same thing with an old Jetta. Found that anytime I used the remote it would disarm and there wouldn't be an issue.
Was digging through VIDA and found that right above the defrost panel there is a line (trace) that apparently runs around the glass near the top for security that sometimes ends up with corrosion from a leaky wiper nozzle seal - which can trigger the alarm. Next time I get a chance to stick my eyeball to the glass I'll verify this.
2023 Lexus RZ450e -66k
Has thanked: 1611 times
Been thanked: 4075 times
Wow..check all those mount bolts, King of Queens. The steel into Al usually don’t loosen up much as they nicely electrochemically bond. I posted a cynical note here once about doing an entire clutch in 12 hours, then spending three to remove the upper torque rod mount bolts
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
brunocerous wrote: 01 Apr 2018, 22:19 My second attempt at replacing a fuel filter was far more successful, with no broken lines and minimal spillage. The bracket took some fiddling with to reattach but otherwise pretty quick.
That bracket is always a pain to get aligned. Glad it went with minimal spillage, though, that's always a plus when working with gas!
erikv11 wrote: 01 Apr 2018, 21:20 wiped me out.
HA! Good one.
wizechatmgr wrote: 01 Apr 2018, 22:47
Maybe some kind of breakage sensor? I'll have to check that out if I feel like removing the tailgate panel ever again.
I'd love to be able to use the remote, but it's broken. I wish I knew what the heck was wrong with it, I've taken it apart and looked it over a million times. The buttons only work every now and again.
brunocerous
bmdubya1198 wrote: 02 Apr 2018, 07:51
Thanks! I always think of the gas station scene in Zoolander whenever I so much as look at a fuel line.
erikv11 wrote: 01 Apr 2018, 21:20 Tightened the wiper blade nut on the T5-R. Again. Exhausting job, wiped me out.
Take the rest of the week off and give your cells some ATP
bmdubya1198
Added a new Volvo to the collection yesterday. '88 740 Turbo M46. Needs some love, but it was $300, so I won't complain too much!
brunocerous
My latest snafu on the '00 V70:
The lower bolt off the right sway end link wouldn't budge, and I even bent the splines on a genuine (not Evolve) Craftsman torx bit in the process. But hey, it looks like a turbo impeller!
I couldn't get a good hold with a vise grip, either, so I pulled out the grinder and nearly lost hope when there was so little bolt material left to manipulate yet too much to remove. Eventually, it relented.
The tie rod completes the AC Delco pair I got in January, with a solid part opposite the bolt, which takes a larger, 17mm nut and uses an 8mm hex counter hold instead of a T-30 torx. So far, so good!
Damage to 3/8-inch drive Craftsman T-30 torx bit
2000 V70 sway end link with mangled bolt
Mangled bolt
Mangled bolt
2000 V70 sway end link replaced
