Vida CEM swapping
RickHaleParker
Been thanked: 958 times
Re: Vida CEM swapping
Post by RickHaleParker »
3r1k wrote: 27 Apr 2021, 13:12 Are you planning to interface via the diagnostic-canbus lines on the CEM (pins 11,12,15,16) without any other can-devices attached? When I tried to do this I never got it to work when no other canbus nodes where connected to the network, instead I had to hook up my canbus-shield to any of the other "real" canbus lines on the CEM and add 120 ohm termination.
Bench testers take note of that.
sparacis
Year and Model: 2009 C30
Has thanked: 1 time
Been thanked: 2 times
Post by sparacis »
Just got a 2008 p1 cem from the local pick and pull to play with as well, really want to be able to pull CEM dumps from the OBD2 port if possible but working with an xprog now to pull the dumps via solder connections
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
When you have P2 on bench, connect pin 8 to +12V and pin 15 to +12V, this makes CEM stay in lock pos 1 and doesn't fall asleep, guess you need to find the same pins in P1.
T5Luke
Post by T5Luke »
sparacis wrote: 27 Apr 2021, 14:21 Just got a 2008 p1 cem from the local pick and pull to play with as well, really want to be able to pull CEM dumps from the OBD2 port if possible but working with an xprog now to pull the dumps via solder connections
You need to write your own bootloader for this, when the problems are solved with P2 i will give it a try with P1 but the CPUs of this both CEMs are very different as the brands are...
RickHaleParker
T5Luke wrote: 27 Apr 2021, 14:22 When you have P2 on bench, connect pin 8 to +12V and pin 15 to +12V, this makes CEM stay in lock pos 1 and doesn't fall asleep, guess you need to find the same pins in P1.
Do you mean pins D:8 & D:15 which are power from the Ignition switch?
If so: A:17 & A:42 on the P1 are the equivalent to D:5 & D:15 on the P2-L & P2-H.
T5Luke
Post by T5Luke »
Yes, i mean D connector. I would give it a try at P1.
RickHaleParker
Project name?
ODIN ( Open Diagnostic INterface ).
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 604 times
Post by vtl »
RickHaleParker wrote: 28 Apr 2021, 05:47 Project name?
I like it! :)
vtl
Post by vtl »
P1 CEM with P2 code path, but no shuffle:
Code: Select all
CPU Maximum Frequency:   600000000
CPU Frequency:           600000000
Execution Rate:          600 cycles/us
Platform:                P2
PIN bytes to measure:    3
Number of samples:       30
CAN high-speed init done.
CAN low-speed init done.
Initialization done.
Putting all ECUs into programming mode.
K-Line keep alive
---> ID=000ffffe data=ff 86 00 00 00 00 00 00
K-Line keep alive
K-Line keep alive
K-Line keep alive
K-Line keep alive
Reading part number from ECU 0x50
---> ID=000ffffe data=50 88 00 00 00 00 00 00
<--- ID=00000003 data=50 8e 00 00 31 25 49 03
Part Number: 000031254903
found PIN: 0x24 0x99 0x68 0x94 0x27 0x69
PIN is cracked in 945.54 seconds
Validating PIN
PIN verified.
done
Resetting all ECUs.
---> ID=000ffffe data=ff c8 00 00 00 00 00 00
In the very first pass. I'm killing the dedicated P1 code.
vtl
Post by vtl »
P1 CEM on the bench pins required:
FRONT-1:23 -> +12v
COCKPIT-1:14 -> GND
COCKPIT-2:11 -> CAN-HS H
COCKPIT-2:12 -> CAN-HS L
