- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
I believe we should all petition Matt to change abscate's user title to "Oetiker Clamp Crusader"
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Has thanked: 2215 times
- Been thanked: 1853 times
Finally got my balanced and checked tires and rims back yesterday (marks were accidentally removed by the tire shop for position on the car and Pirelli tires are bi-directional.........!!). Removed the slave tires and rims used for winter storage and fitted summer tires. Checked car over and then decided to take it for a run if it started.
It fired right up, valved chattered for a few seconds (car has stood for 7+ months, oil pan o-rings were replaced about 3 years and 2500 miles ago) and then quietened down. Took for a gentle 5km run around the neighborhood to get the engine up to temp and then gave a little more boost and it ran nicely and no wheel wobble!
Got home, cleaned the windshield and tomorrow go out and check no leaks and then hand the keys over to the boss for the summer duties for golf runs. Sad to see all the new scratches , scrapes and small dings on the passenger side of the car from careless car owners. Breaks my heart to see it. I might try and buff that side over next winter and see if I can coax some of them out of the paint.
- Has thanked: 1613 times
- Been thanked: 4078 times
While randomly scanning Parts Geek, I found m56 differential bearings.
Also, this confidence inspiring control arm listing
TRQ Control Arm Ball Joint Tie Rod and Sway Bar Link Kit - Front
Part Number: 868-02777030
Brand: TRQ
Notes: with 4 Bolt Style Control Arm; with TRW Steering Rack
Complete Assembly: No modifications or assembly required
Carbon Brush and Commutator: More than twice the service life compared to copper
Flourine Rubber Seals: Resistant to high temperature, fuel, and solvents
Automatically adjusting pressure regulator for improved service life
SAE J2044 Compliant: Improved mounting security, minimized installation error
Show More
- Has thanked: 317 times
- Been thanked: 531 times
Wow, carbon brushes AND self adjust pressure regulator? Those are some advanced control arms!abscate wrote: 08 May 2022, 03:56 While randomly scanning Parts Geek, I found m56 differential bearings.
Brand: TRQ
Show More
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I am intrigued.abscate wrote: 08 May 2022, 03:56 While randomly scanning Parts Geek, I found m56 differential bearings.
Brand: TRQ
Show More
Finally got around to reclamping Abby’s exhaust junction on Evita. Car up on one side with ramps , 2 inch band clamp over ball and socket joint held into position with tipped jack stand. Used permeatex exhaust glue to help seal, idle for ten minutes to warm it up.
Much quieter.
Caitlin helped me finish shutter painting , too!
Exhaust plate 4x M8 bolts, 12 mm hex
Band clamp 2 inch SS , 14 mm hex bolts, deep socket
Husky guarding the Ferry
Much quieter.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Tailgate latch ( 8628917 ) failed closed. No amount of patient troubleshooting or Salty Sailor Swearing helped.
I was too invested in being folded up in the back of the car to take pics of the Odyssey pulling the rear inner trim panel/card.
There were eight (8) very nice, long sheet metal screws involved. Undetermined if it will be salvageable. The top rear screw was also stripped. Both Dremels, several hammers, and a stout sacrificial screwdriver later, Fortunately Poor Old Blue has been harvested again.
Detailed post-mortem of the old latch after my blood pressure gets out of four digits.
Johnson ? used to supply Costco up here in Canada. only knew this as I knew one of the guys involved. Don't know now, but they used to be good batteries even in our winters.
I have Everstart Walmart batteries in pretty much all of my cars. They're good overall, never had issues with them.
