The I Worked on My Car Today Thread
2000 V70 Tailgate Trim Rattle Fix
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
I bled my rear brakes today
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
Got the dreaded blinking arrow but tranny was shifting fine...cleaned out the gunk in the throttle switch at the firewall and all is good. I really need to donate some cash to this site...it's saved me bundles. I will, I will...
1998 V70 R >267K
2004 XC70 >171K
2004 XC70 >171K
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
Today, I bleed the brakes with new ATE Blue Racing fluid. It does look very good and can see the mark (max) level without my glasses. While underneath, inspected the fron and rear suspension. Not surprising, one rear shock and one front strut leaks. So after the timing belt task, I'll save enough to do most all (90%) of the suspension. The upper engine mount was replace serveral years ago with IPD HD bushing. The lower engine mount looks suspect, (will change), transmission mount fair (will change), control arm (right) suspect, (left was replaced last year), tie-end rods, suspect, endlinks (new IPD HD), anti-sway T5 factory sports (trashed) and I do have new (Polys) for that. I did notice an oil leak coming from near the waterpump area on the outside the timing-belt cover. With the new TB kit (with seals( that should cover it. Hope everyone has a great weekend.
98 S70 T5-M Brick for life
Marcobrick
- Year and Model: 2003 V70T5
- Has thanked: 3 times
Just done: Swapped worn and leaking Nivomats for standard springs and shocks
Next week
Wagon:
Replace spring seats and strut top bearing plates
Replace top engine and firewall torque mount bushings
Replace bottom transmission mount bushings
Clean out PCV System
Change spark plugs
Remove and recondition turbo with new seals and bearings new BOV (never done it but how hard can it be....)
Replace thermostat
Replace oil cap seal
Change the oil
Change the transmission fluid
Remove and clean the PNP switch
Replace bad main battery cable
Replace timing belt, tensioner and idler rollers and water pump.
T5 sedan: Fix odometer some time.. only about 25,000km in arrears!
Makes me tired just thinking about it! Oh, and the wife would like me to renovate the spare bedroom too as we have #3 on the way...
If I discover anything clever in my work, I'll post about how I did it.
Next week
Wagon:
Change spark plugs
Replace thermostat
Change the oil
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Zoidberg
- Year and Model: S60 2.5T 2006
Inspected the front end to find the source of an intermittent clunk while braking. While I was under there, I decided to remove, clean and re-grease the caliper slide pins, and I drained and refilled my transmission with Mobil 3309 (yeah it's the five-speed so I gotta use the special stuff)
All in all it went pretty well except I think I need new sway bar endlinks and new brake hoses...
Juan62
Yesterday, changed the EVAP hoses (both), and today SAS check valve. The hardest/longest time I experienced with the EVAP were removing the factory clamps. After removal of hoses and inspection, I did see cracks from normal wear/tear. I recommend replacement of these hoses.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Yesterday finished timing belt along with water pump, idler roller, tensioner roller, tensioner, and new serp belt.
Sunday and today combined:
Timing belt only(car only has a verified 72k miles)
Replaced one missing lug stud
New KYB shocks
New KYB Struts
New (to me) leather steering wheel
Cleaned and gapped plugs
Siliconed the rip in my MAF tube
Repaired ABS module with my new soldering iron
Cleaned the underside of the engine bay and frame with a bunch of GoJo
Replaced cabin air filter
Added roof rails and crossbars from a salvage yard 850 wagon
New KYB shocks
New KYB Struts
- 21 Replies
- 6766 Views
- 955 Views
Last post by Craigd2599
- 1883 Views
Last post by rspi
- 820 Views
Last post by Clemens
- 26 Replies
- 6547 Views
Last post by ChadLee
