Help with powering S60 seat -- Not in a Car Topic is solved
- Been thanked: 4064 times
We have all the information in a pdf in our secret files, and can release it if you ship your M66 AWD components to each moderator on this site, and two to Matthew.
Each motor has two wires only,so worst case you could just use a double pole, double throw center off switch to put the right polarity onto the motor and use your head and senses to control the limit switch.
A fuse could be used to limit the stop too, as a safety.
Joshude
- Year and Model: 2005 V50 T5 AWD M66
- Has thanked: 2 times
My M66 AWD stays with me!
Okay, i've read something, that the drivers seat might be more complex. But if I integrate the stop-switches for power-off when been hit i should not worry to burn my car down?
Or just use any high-current-compatable switches in first place?
Sorry, as i mentioned i couldn't look into the seat and the electronics yet, but my plan was just to wire the seat to 12V, fused and in best case only with acc on.
€: If someone has the part number for the activation of the powered memory drivers seat, i'll take that, too. Maybe if the price isn't too high i just go that route. But since now no one was able to find that number
I just had a P80 (1999) car seat apart - I have not done a P2 (2001-2007) but Im sure the motors have the same two wire inputs.
I just checked the wiring diagram and indeed pin 1 and 2 on each seat connector is the motor wires - four motors per seat
Seat Fore/aft
Seat height
Seat bottom tilt
Seat back tilt
Seat Fore/aft
Seat height
Seat bottom tilt
Seat back tilt
ive been looking at theses posts about powering the electric seat im trying to do the same with mine as mine was a manual seat i just cant get this power seat to move id like to wire it from the battery.any help would great as im am now at my wits end.heres a pic of the board for the switches.if you could show me where to put the wires on here or give me detailed description on how to do it that would be fantastic other wise ill have to get another manual seat .thanks.
Hello Neil
The P2 model you have is very different. Those switches send control signals to a seat module which sends motor current
You will have to lift the seat out and find the motors and wire directly
sorry for not getting the wire direct motor thing how am i going to get the motors to go in both directions all help would be good .if you could tell me what i would need in order to do this .and maybe give me some idea on how to wire them up would be brill.
- 2064 Views
Last post by Oleelstad
- 1983 Views
Last post by darylrobert
- 2164 Views
Last post by zoli_m13
- 1559 Views
Last post by vtl
- 5490 Views
Last post by ektrules
