Vibration at idle and acceleration after hitting a deer
mrjay62
- Year and Model: V70XC 2002
- Been thanked: 3 times
Ok thank you...
Seems and sound the same. But the vibration in the car is not something I've ever had before the deer .
The only other cushions/bushings I can think of is from the top of the struts?
Spend over an hour with 2 used coils I have switched them out every which way with no change.
Even left the upper engine mount and strut mounts support Bar disconnected didn't change the vibration in the car..
So that's where I'm at...
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
I know it may be uneasy for your neck, but what happens when you disconnect the steering column from the steering shaft (the one that goes into rubber "plunger"? One bolt only. In theory, if vibration comes through the steering rack, it is transferred to the steering wheel, apparently, and to the chassis through the steering column.
Always questioned the idea of mounting rear engine pad on the steering rack...
- Has thanked: 2857 times
- Been thanked: 1332 times
Jay, can you put the video on YouTube? Or if not that, anywhere? Dropbox, iCloud, etc. I can pull some strings with the President of the Internet and make it appear here.
mrjay62
Hi Matthew.
Are you talking about my video of the water bucket of water on the engine? It's exactly the same as vlt's video.
I'll have to figure out how i can set up Dropbox, iCloud,Utube etc.
Not the brightest blub in the box here..
- 1002 Views
Last post by oragex
- 24 Replies
- 2451 Views
Last post by TisMe
- 1705 Views
Last post by oragex
- 6047 Views
Last post by Volvogurl89
- 811 Views
Last post by c70_lindsay
