P80 Fuel Pump Relay Repair master thread 9434138 9434225 Topic is solved
This topic is in the MVS Volvo Repair Database » Volvo Fuel Pump Relay Repair
Kazthebassman
Year and Model: C70 1999
Has thanked: 2 times
Re: Fuel Pump Relay Repair
Post by Kazthebassman »
Thanks Abscate, maybe I was confusing it with the ECU repair.
andyg498
Year and Model: 1994 850
Post by andyg498 »
Interesting. I may look for bad solder joints, but doubt if I will switch out the capacitors. Anyhow, the main reason I am responding. My 1994 850 has T-20 Torx screws, not T-25!
andyg498
Post by andyg498 »
O'Reilly and one other place I looked had the completely wrong relay listed in their catalog and online. Not even close, even had round prongs instead of flat.
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Advance always has the master fuel system relay listed as the fuel pump relay. Like you said, its not even close.
configsys
Year and Model: V70R
Been thanked: 5 times
Post by configsys »
Was troubleshooting a no fuel condition on my '00 V70R and after playing with DICE/VIDA it indicated the fuel pump relay was functioning (intermittently I guess) so I thought the fuel pump was bad - have to drop the entire rear sub-frame/suspension and tank (major labor $$$) to replace it. Not only that, it has a 2-part system, one is a fuel pump and the other a fuel ejector at a cost of $330 and $376 respectively.
So this morning I decided to make sure and jumpered pin 15 & 87 and sure enough - got the car started. Turns out the fuel relay was bad and I was able to pick one up at the junk yard for a whopping $2.49!
Thanks so much for this thread as I was able to avoid a tow, mechanics troubleshooting, and perhaps getting ripped off on spending thousands on a fuel pump replacement!
'16 S60 AWD
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
Has thanked: 1500 times
Been thanked: 3810 times
Added part number to top of thread for search,
Lol, when was the last time someone at Radio Shack could solder something?
