I don't have the equipment to extract a bin file.
Vida CEM swapping
- RickHaleParker
- Been thanked: 980 times
Active
Past
Past
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
You probably do. It only needs a USB-serial converter (the one with RX/TX lines). T5Luke taught me how to read/write Renesas flash with such adapter and m16c-flasher.de software.
vtl
It always picks 0 even if bytes go down from 99 to 0.RickHaleParker wrote: 04 May 2021, 13:44 What happens if you exclude 00 as a candidate? say measure 01 - 99 rather then 00 - 99.
May need to power on the oscilloscope once again.
- RickHaleParker
I seen that someplace before but never gathered enough information and software to do it.vtl wrote: 04 May 2021, 18:10 You probably do. It only needs a USB-serial converter (the one with RX/TX lines). T5Luke taught me how to read/write Renesas flash with such adapter and m16c-flasher.de software.
You assumed correctly, I do have a FTDI USB <=> RS-232 DB9 adapter.
Got a link or a file? ... enlighten me.
Got four platforms to work on. Ubuntu 20.04, Windows 10, OS X Leopard PPC and MorphOS 3.15 .
Found this in a yard sale for $1.00.
Had no use for it at the time but figured I would end up kicking myself in the rear if I did not buy it.
Active
Past
Past
- RickHaleParker
Got the software and the manual but, the manual is mute on how to connect the serial cable to the Microcontroller.
Active
Past
Past
solitaire
- Year and Model: v40 2016
- Has thanked: 3 times
- Been thanked: 6 times
vtl wrote: 03 May 2021, 04:35Thanks. Do you have a dump for that CEM?solitaire wrote: 03 May 2021, 01:21 Part Number: 30795115
Searching P/N 30795115 in 49 known CEMs
Candidate PIN 94 53 06 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 640 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..55%..60%..65%..70%..75%..80%..85%..90%..95%..
PIN is NOT cracked in 1220.88 seconds
done
Resetting all ECUs.
first two ok, third - no
94 53 85 25 40 55
ATTACHED
- m30855f_30795115_FLASH.rar
- (114.75 KiB) Downloaded 177 times
vtl
Yes. Renesas has its own flash access protection countermeasure, but they are not enabled in Volvo CEMs.blasaab wrote: 05 May 2021, 08:46 Is it possible to read cem with m16c flasher software without pin?
- 9825 Views
Last post by RickHaleParker
- 10118 Views
- 27 Replies
- 31220 Views
Last post by cn90
- 11896 Views
Last post by jonesg
- 6897 Views
