Picked up my '94 850
volvofornia
Year and Model: '94 850 T5
Post by volvofornia »
Well, as far as I know there is no 93 Octane here in LA :(
'94 850 T5 - 150k Miles - hopefully soon daily driver
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
dosbricks wrote:A loose positive terminal can stall a car and also be intermittent....
Yes it can,but not with the idiot lights on since there would be NO electricity because battery terminal was loosened or disconnected for a splice of second.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
dosbricks
Been thanked: 4 times
Post by dosbricks »
volvofornia wrote:It also happened during driving downhill. Just a coincidence?
Probably not a coincidence if the battery was not secured with it's hold down-clip.
dosbricks
Post by dosbricks »
Intermittent means on and off and back on. :wink:
volvofornia
Makes sense. I'll have a testdrive today. Lets see what my moody little 850 will give me today :)
volvofornia
So far she didn't stall anymore. But my knock sensor code came back. Time to pull the trigger for a new set.
Hope they arrive fast!
Has thanked: 1610 times
Been thanked: 4065 times
My indie told me the knock sensors never go bad. I had the code, replaced them and still had the code. CVVY solenoid replacement finally fixed mine. I donated my still good old ones to this Board, losing money but gaining both wisdom and karma...
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Knock sensors are really just microphones and usually an ohmmeter test will tell you if they are good or not. The torque is pretty important on the mounting bolt. If they get overtightened it can mess up the deflection on the microphone element, much like sticking your finger on a speaker.
volvofornia
abscate wrote:My indie told me the knock sensors never go bad. I had the code, replaced them and still had the code. CVVY solenoid replacement finally fixed mine. I donated my still good old ones to this Board, losing money but gaining both wisdom and karma...
How did you narrow it down to the solenoids? Did you had the same code P0326?
I had an intermittent code P0326? which codes to knock sensor - BUT - if you scour the webs the software sets this code if the ECM is unable to resolve engine detonation by retarding the timing. Thus, even though you get a knock sensor code, this is not pointing you to replacing the knock sensor, but figuring out why your engine is pre-detonating. Usuall suspects here - ignition system, fuel delivery, vacuum leak, gross engine problem.
I started getting the CVVT error (I only have EX-CVVT on my 1999) and cleaning the solenoid made it go away for three months - eventually I replaced with a used one, given generously be Lee.
