2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
2004 S60R -- Yamaha V8 Conversion!
- Has thanked: 316 times
- Been thanked: 531 times
Came across this on FB this morning, I was excited to see another B8444S swap in a P2R!
- Capture.PNG (447.6 KiB) Viewed 1983 times
- RickHaleParker
- Been thanked: 980 times
Is he doing engine and transmission?bmdubya1198 wrote: 29 May 2020, 09:28 Came across this on FB this morning, I was excited to see another B8444S swap in a P2R!
I'm getting there.
Active
Past
Past
Yup, he’s doing an M66.
- RickHaleParker
I had a chat with him on Facebook. He is starting off with a 2006 S60R. His electrical, electronics and software should be pretty much plug and play. I told him where to find MVS and Yagger if he runs into a problem.
The B5254t4 is shot. Sometime between when I got it and how, it went to full lock up. Most likely the Antifreeze in the crankcase rusted everything in the lower end.
Active
Past
Past
Yeah, that motor was junk.
- Has thanked: 987 times
- Been thanked: 1076 times
Now what? Find another V8?
Nah, he’s talking about the B5254T4. The original motor.
- RickHaleParker
The original 2.5L is now locked up, I could turn it over when I got it.
If you look above I was think of salvaging the internals in case somebody wanted them. Pistons new are $160.00 each. Connecting rods new are $200.00 each.
Active
Past
Past
- RickHaleParker
Notes: In 2005 Volvo changed the High Speed CAN bus speed from 250 Kbps to 500 Kbps.
Control modules on the HS bus: ABS/BCM, DEM, ECM, ETM, SAS & TCM.
Active
Past
Past
- Been thanked: 4071 times
I’ve got one of those them there fast 2005 Busses.
