My buddy recently swapped his backrest cover on his 850 for one from a passenger side. Only real issue is the lumber support knob that comes out the opposite side, so you have to make one on the other side and have a hole on the other one. If you are really particular, you might be able to get an upholsterer to either patch it or swap it over from the original seat cover.
- Has thanked: 2215 times
- Been thanked: 1853 times
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 278 times
- Been thanked: 85 times
I did nothing to my Volvo today, I just drive it. It runs really well at the moment, engine is silky smooth, new tires improved the ride a lot.
But I do have an issue with the windshield washers. They come on delayed, I replaced the small 3way valve under the hood, but it still feels delayed. I took the old valve apart and there was a piece of "something" stuck in it, after removal it seems to work again. There should be a filter in the line somewhere right? Maybe I need to clean the system
850 T5-R '95 auto
- Has thanked: 1613 times
- Been thanked: 4078 times
I still have spare material in charcoal or beige to cover that hole, for a postage stampscot850 wrote: 22 Jun 2023, 19:09 My buddy recently swapped his backrest cover on his 850 for one from a passenger side. Only real issue is the lumber support knob that comes out the opposite side, so you have to make one on the other side and have a hole on the other one. If you are really particular, you might be able to get an upholsterer to either patch it or swap it over from the original seat cover.
viewtopic.php?t=84734&start=40
Blew the repaired fuel hose off the junction from the fuel filter...again....
Thanked Kat for taking me 140 miles to Manhattan and back , then failing hose 1/4 mile from garage. Walked home, got P2, got bagels, put in toaster, went back and hard-towed Kat back home
Roughed up NiCopp line, JB weld, and double FI clamped it this time like others. tight access. Used old radiator hose to chafe relief the clamps on the fuel filler neck.
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
Someone had a thread here where they swapped right to left seat covers. They cut a piece off the bad seat cover and stitched or glued it inside under the lumbar hole. Looked much better than a beat up seat cover.scot850 wrote: 22 Jun 2023, 19:09 My buddy recently swapped his backrest cover on his 850 for one from a passenger side. Only real issue is the lumber support knob that comes out the opposite side, so you have to make one on the other side and have a hole on the other one.
Did it fail both times 1/4 mile from your house after drives to Manhattan? That's a lot of karma you have banked up.abscate wrote: 23 Jun 2023, 08:45 Blew the repaired fuel hose off the junction from the fuel filter...again....
FireFox31
Once 1/4 mile and once 3 miles.
My Karma cup doth run over
- Has thanked: 987 times
- Been thanked: 1078 times
Some people are just REALLY LUCKY like that.
(other people are suspicious of all that luck)
volvolugnutr
volvolugnutr
Wish I could get good bagels here. All we have are stale Bimbo Bakery things that are called bagels.abscate wrote: 23 Jun 2023, 08:45 Blew the repaired fuel hose off the junction from the fuel filter...again....
- Has thanked: 317 times
- Been thanked: 531 times
A REALLY good bagel place opened probably 6 months ago 5 minutes down the road from me. Fortunately we have a lot of NY transplants down here who know how to make bagels and pizza.
Not combined, of course!
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
I have a strange windshield wiper issue too. When I flick the wiper switch forward to rinse, it stays on until I pull the fuse. The first time this happened, the reservoir emptied itself before I could figure out that pulling the fuse was the only way to stop it.hausmeister wrote: 23 Jun 2023, 01:18 I did nothing to my Volvo today, I just drive it. It runs really well at the moment, engine is silky smooth, new tires improved the ride a lot.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
