VIDA 2012B VMWare Player Image
precopster
- Year and Model: Lots
- Been thanked: 128 times
That is the ONLY way to connect a VM. Glad you got it sorted.
mrscullini
- Year and Model: 05 XC70, 08 XC70
- Has thanked: 1 time
thanks.precopster wrote:That is the ONLY way to connect a VM. Glad you got it sorted.
i was able to connect and pull data from the wife's car. she has an '08 with keyless start so it had to be running. not sure what the number II position is with keyless.
now it is a matter of navigating through vida to figure out where everything is. i've been looking for a user guide but haven't found one, is there one floating around out there?
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Pulling data on the run is fine; however, there are quite a few tests that require Ignition ON but do not make sense with the engine running. (And one would not want to perform those on a running motor either).mrscullini wrote:
...with keyless start so it had to be running. not sure what the number II position is with keyless...
See the attached Manual that came with the install cd (mine is v. 2011A but most of the information will be identical)
Hope this helps
VIDA DiCE_Manual.pdf- Manual
- (3.65 MiB) Downloaded 455 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
mrscullini
thanks!! fortunately (knock on wood), i don't have a need for vida/dice at the moment. when the time undoubtedly comes, i want to make sure i know how to use the tool.regent wrote:Pulling data on the run is fine; however, there are quite a few tests that require Ignition ON but do not make sense with the engine running. (And one would not want to perform those on a running motor either).mrscullini wrote:
Hope this helps
mrscullini
just an fyi, i have had success with this dice unit and the vida image,
http://www.ebay.com/itm/VOLVO-VIDA-DICE ... D100102%26
the seller is in so cal and shipped very quickly. the seller has also been great about communication and offering tech support.
mattfromtn
- Year and Model: 1998
I try to open with vmware and get a error, specified file is not a virtual disk. Any thoughts?
freedomgli
- Year and Model: 2010 XC70
In for later.
precopster
I posted 2014A as an installable program in the Vida Dice forum. Do you need to have a virtual setup? If so I also have links to the files on my own cloud server. Let me know.
precopster
Here's some new links:
https://mega.nz/#!clQ2DQrS!JPNMDyRNy9pC ... La9uiHZVkE
https://mega.nz/#!Iwx1nZBK!SzjqVTnXucES ... AG7uAqXQec
https://mega.nz/#!1wBWnIDI!TfjW8j7mtdwA ... Ncf6VLGXwU
https://mega.nz/#!EgICBSJL!QrVMIBwatypK ... rhFtw-aBwQ
https://mega.nz/#!llJCFY6A!VQAZyWa4ZC-g ... zr2Ddm5bNQ
https://mega.nz/#!UpAGFCbD!U1K8mQhYLgOy ... GLYijaidfE
https://mega.nz/#!Fg4HEIKI!dCjiwBbNPQ6d ... EvWEAckQcI
- 1196 Views
Last post by mrscullini
- 2875 Views
Last post by Sardine
- 1115 Views
Last post by suds
- 1624 Views
Last post by RickHaleParker
- 1676 Views
Last post by XC70Rider
