Started reassembling the interior over the weekend.
And tonight, my manual pedal pack came in. Yay!
However, swapping out the slushbox pedals for the proper set is yet another one of those car operations which requires you to be upside down and backwards and twisted and generally in pain.
I don't know, maybe I don't have the right temperament for this hobby. I spent the last hour screaming at the car while swapping the pedals. I'll leave the specifics to the reader's imagination, but this car is riddled with design flaws.
Or rather, one BIG one: The entire vehicle was designed to be manufactured, not repaired. It's a giant onion designed to go together ONCE, on an assembly line, with bolts and seals that can't be reused because of certain compromises made to satisfy conflicting design parameters.
Nevada1906 1995 850 S60R m56 build thread
- Nevada1906
- Year and Model: 1995 850 Turbo
- Been thanked: 30 times
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
- Has thanked: 316 times
- Been thanked: 531 times
Ah yes, installing pedals… one of my least favorite jobs! It’s always a painful job… I’m 6’3”, so I don’t have a good time folding myself under a dash.
If you’re not cursing at the car while installing the 850 pedal bracket, you’re some kind of wizard. I’ve only ever removed them from 850, and it’s a massive pain. Way better design on the X70s.
- Has thanked: 1611 times
- Been thanked: 4072 times
Working under dash?
Four M10s , electrical plugs, and the driver seat comes out!
- Nevada1906
Driver's seat was out before I did the job. That only makes it LESS of a pain-in-the-ass job.abscate wrote: 06 Apr 2022, 03:13 Working under dash?
- Has thanked: 2864 times
- Been thanked: 1332 times
I'm 6'3" also and anything under my 850's dash was miserable. Relays, wiring, vacuum lines, all painful.
- Nevada1906
HEY KIDS, WHAT TIME IS IT?
IT'S FLYWHEEL TIME!!!
That nasty-looking upper mount is only there temporarily, to lift the engine and transaxle into the car. I'm replacing it with a new part. I know I said I wanted to use a modded 850 upper mount, but unless this one is egregiously out of position, I'm using it. I also decided to yank the old serpentine belt - it was more worn out than my dad's sense of humor.
Now, onto the rear main seal.
You don't need a seal driver to install the rear main. I used a hammer and a 3/8" extension. Just go around the seal and slowly (and gently) tap it into place. Also, here's a trick. I put a little 10W30 on the seal face so it'll slide over the crank flange.
Also, kudos to the machine shop. They did a hell of a job resurfacing my eBay flywheel. Eh, the transaxle gears did the same thing to me when I opened it up to inspect it.
New bolts, torqued and angled into position.
And both units are ready to mate up, as soon as my new clutch comes in, supposedly Monday.
Coming along nicely!
You could have saved ooodles of money with a URO main crank seal….
( ducks under bridge)
That would have been very well with the cost savings!abscate wrote: 09 Apr 2022, 02:39 You could have saved ooodles of money with a URO main crank seal….
Especially when you're back under there again in 6 months!
- Nevada1906
bmdubya1198 wrote: 09 Apr 2022, 09:39That would have been very well with the cost savings!abscate wrote: 09 Apr 2022, 02:39 You could have saved ooodles of money with a URO main crank seal….
What IS the deal with URO, anyway?
- 3049 Views
Last post by CorpsOfficer
- 2162 Views
- 14 Replies
- 1315 Views
- 13040 Views
- 11 Replies
- 19526 Views
Last post by volvolugnut
